Results 1 to 9 of 9
Thread: How do i change worksets for my Linked Models
    September 17, 2020
    UK
    11
    06:50 AM
    So Basically i have 2 links, Arch and Mech. I linked them in today but they've both been placed under my lighting workset, I can't seem to change them to their respective worksets as it is greyed out.
    Can anyone help?
    Will i need to unload them and when i reload them, specify which workset to use??
    1,712
    06:50 AM
    Not a 100% sure, but just delete them from your project, set the right Workset active and re-link them is my guess.
    September 17, 2020
    UK
    11
    06:50 AM
    Was the easiest and quickest solution. thanks
    1,712
    06:50 AM
    sometimes the easiest solution is the one you overlook. Happy it got sorted.
    3,247
    01:50 AM
    In the Project Browser, scroll down to the bottom of the list. Find "Revit Links". Double click on the link that you want to assign to another workset. In the Type properties, you can change the Workset property of the link. See also if the instance property shows the same. If not, after changing the type parameter, you can select the link from the Project Browser as well, doing Right click > Select all instances.. Then change the Workset instance property.
    2,837
    03:50 PM
    Make sure your active view has 3D elements in it. I've seen this happen in drafting views or sheets with no views added.
    3,247
    01:50 AM
    Is that related to this thread or another?
    September 17, 2020
    UK
    11
    06:50 AM
    Thank you for your detailed response but in this instance i was unable to change it in this manner as the workset had been greyed out.
    2,837
    03:50 PM
    Related to this thread, although it seems i was mistakenly refering to reloading or adding new links through the workset dialogue....
  1. Worksets within linked files
    By robp in forum Architecture and General Revit Questions
    Last Post: January 17th, 2020, 08:48 AM
  2. turn on/off worksets in a linked model
    Last Post: September 8th, 2017, 06:15 PM
  3. Linked Models/CAD and Worksets
    By wwdreamb in forum Architecture and General Revit Questions
    Last Post: August 24th, 2017, 07:15 AM
  4. Linked Models & Worksets
    By kirklyncox in forum Architecture and General Revit Questions
    Last Post: May 21st, 2014, 05:04 AM
  5. linked Model unloads when editing worksets
    By londonhksgeek in forum Architecture and General Revit Questions
    Last Post: November 7th, 2013, 03:46 PM
