Thread: Revit 2021 - Moment Frame symbol, Brace Frame & bonus question
    January 6, 2019
    06:43 PM
    [FONT=Roboto]I'm using Revit 2021 (Structure) version 21.1.1 and I have a graphics issue with the moment frame symbol and vertical bracing frames. They come out too fat and blurry (see images). The moment frame symbol is the OOTB version. Any ideas on fixing this would be appreciated.
    My bonus question is, in 2021 I cannot double click a section symbol to go to it's view. I must now right click and "go to view". is there a setting to bring back the double click?
    Cheers!
    [/FONT]
ID:	39463   Click image for larger version.
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    303
    05:43 PM
    The moment frame and vertical bracing elements are annotation symbols. Their appearance can be controlled under Annotation Categories in Visibility/Graphic Overrides. They are "Connection Symbols".
    I'm not sure about double clicking a section symbol. Are you using the OOTB section head? Or is it a custom family?
    January 6, 2019
    06:43 PM
    Thanks for the reply Tony. I was aware of the connection setting you mentioned, but to no avail. I have a resolution to my issue though. I had a filter running for the beams and bracings which took control over the VG overrides. After some adjusting of the filters I was seeing things back to my liking.
    As for the double clicking, all is working as normal today. Dunno why it was acting up since the initial install, but for the past 24 hours it's been ok. All part of the fun going on in 2020.
  1. Moment Frame symbol is grey
    By arcticnyc in forum Structure - General Questions
    Last Post: August 12th, 2017, 12:25 AM
  2. Replies: 1
    Last Post: July 17th, 2017, 08:40 AM
  3. Revit Timber Frame Extension Question
    By Brad Peters in forum Architecture and General Revit Questions
    Last Post: June 28th, 2016, 05:00 PM
  4. Revit OpEd: Window or Door Frame Positioning
    Last Post: April 23rd, 2013, 06:15 PM
  5. Brace Frame Connections
    By Mr_Greg in forum Structure - General Questions
    Last Post: January 14th, 2013, 09:27 PM
