Results 1 to 10 of 11
Thread: Importing Views from Arch Model.....
    September 29, 2020
    5
    05:19 PM
    I get this.....Anyone know how to fix this?
    Revit 2021
    1,712
    11:19 PM
    that image went wrong, can you upload it again please
    September 29, 2020
    5
    05:19 PM
    3,405
    05:19 PM
    melizondo:
    As a new user, you aren't allowed to upload files yet.
    Once you've had 5 posts approved by moderators, you will be able to upload.
    September 29, 2020
    5
    05:19 PM
Name:	Screenshot 2020-09-29 131024.png
    September 29, 2020
    5
    05:19 PM
    oh ok, basically i get a popup.
    Code:
    Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
    Copying one or more elements failed.
    Details
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    Autodesk.Revit.Exceptions.InvalidOperationException: Copying one or more elements failed.
       at Autodesk.Revit.DB.ElementTransformUtils.CopyElements(View sourceView, ICollection`1 elementsToCopy, View destinationView, Transform additionalTransform, CopyPasteOptions options)
       at Revit.DLR.ProjectSetup.ApplySelectedParametersButton_Click(Object sender, EventArgs e)
       at System.EventHandler.Invoke(Object sender, EventArgs e)
       at System.Windows.Forms.Control.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ButtonBase.WndProc(Message& m)
       at System.Windows.Forms.Button.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    UIFrameworkInterop
        Assembly Version: 21.0.0.0
        Win32 Version: 21.1.1.109
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/UIFrameworkInterop.DLL
    System
        Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    UIFramework
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/UIFramework.DLL
    CefSharp.Core
        Assembly Version: 65.0.1.0
        Win32 Version:
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/CefSharp/CefSharp.Core.DLL
    UIFrameworkServices
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/UIFrameworkServices.DLL
    CefSharp
        Win32 Version: 65.0.1.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/CefSharp/CefSharp.DLL
    System.Core
        Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    PresentationFramework
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
    WindowsBase
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
    PresentationCore
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
    System.Xaml
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
    System.Configuration
        Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
        Win32 Version: 4.8.3752.0 built by: NET48REL1
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Xceed.Wpf.AvalonDock
        Assembly Version: 2.0.19.12
        Win32 Version: 2.0.19.12
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Xceed.Wpf.AvalonDock.DLL
    Autodesk.UI.Themes
        Assembly Version: 2.16.0.0
        Win32 Version: 2.16.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.UI.Themes.DLL
    UIFrameworkRes
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/UIFrameworkRes.DLL
    AdWindows
        Assembly Version: 3.0.4.0
        Win32 Version: 3.0.4.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AdWindows.DLL
    WindowsFormsIntegration
        Win32 Version: 4.8.4150.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
    PresentationFramework.Aero2
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
    System.Drawing
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    AdApplicationFrame
        Assembly Version: 0.0.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AdApplicationFrame.DLL
    AddInManagerUI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddInManagerUI.DLL
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    PresentationFramework-SystemXml
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
    System.Windows.Controls.Ribbon
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Controls.Ribbon/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Controls.Ribbon.dll
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
    Microsoft.Expression.Interactions
        Assembly Version: 4.5.0.0
        Win32 Version: 3.0.40218.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Expression.Interactions.DLL
    UIAutomationTypes
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
    UIAutomationProvider
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
    PresentationFramework-SystemCore
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
    APIInterop
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/APIInterop.DLL
    RevitAddInUtility
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitAddInUtility.DLL
    System.Xml.Linq
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
    PackageContentsParser
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/PackageContentsParser.DLL
    RevitAPIFoundation
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitAPIFoundation.DLL
    RevitAPIIFC
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitAPIIFC.DLL
    IntfIFCAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/IntfIFCAPI.DLL
    RevitDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitDBAPI.DLL
    RevitAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitAPI.DLL
    AddInManager
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddInManager.DLL
    GraphicsAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/GraphicsAPI.DLL
    UtilityAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/UtilityAPI.DLL
    GeomUtilAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/GeomUtilAPI.DLL
    FamilyDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/FamilyDBAPI.DLL
    EssentialsDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/EssentialsDBAPI.DLL
    RoomAreaPlanDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RoomAreaPlanDBAPI.DLL
    ArrayElemsDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/ArrayElemsDBAPI.DLL
    StructuralDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/StructuralDBAPI.DLL
    HostObjDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/HostObjDBAPI.DLL
    SculptingDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/SculptingDBAPI.DLL
    ElementGroupDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/ElementGroupDBAPI.DLL
    CurtainGridFamilyDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/CurtainGridFamilyDBAPI.DLL
    SiteDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/SiteDBAPI.DLL
    DetailDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/DetailDBAPI.DLL
    BuildingSystemsDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/BuildingSystemsDBAPI.DLL
    EnergyAnalysisDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/EnergyAnalysisDBAPI.DLL
    IntfATFAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/IntfATFAPI.DLL
    MaterialDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/MaterialDBAPI.DLL
    AnalysisAppsDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AnalysisAppsDBAPI.DLL
    StructuralAnalysisDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/StructuralAnalysisDBAPI.DLL
    RebarDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RebarDBAPI.DLL
    AssemblyDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AssemblyDBAPI.DLL
    StairRampDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/StairRampDBAPI.DLL
    APIDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/APIDBAPI.DLL
    DPartDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/DPartDBAPI.DLL
    PersistenceDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/PersistenceDBAPI.DLL
    InterfaceUtilAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/InterfaceUtilAPI.DLL
    InterfaceAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/InterfaceAPI.DLL
    PointCloudAccessAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/PointCloudAccessAPI.DLL
    NumberingDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/NumberingDBAPI.DLL
    MassingDBAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/MassingDBAPI.DLL
    Autodesk.ATFTranslationServer.DBApplication
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Autodesk.ATFTranslationServer.DBApplication/Autodesk.ATFTranslationServer.DBApplication.dll
    Autodesk.CivilAlignments.DBApplication
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/CivilAlignments/Autodesk.CivilAlignments.DBApplication.dll
    Autodesk.CoordinationModelDB
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/CoordinationModel/Autodesk.CoordinationModelDB.dll
    Autodesk.LinkTopography.Parser
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SiteLinker/Autodesk.LinkTopography.Parser.dll
    Autodesk.ResultsBuilder.DBApplication
        Assembly Version: 2021.0.0.0
        Win32 Version: 2021.0.0.2
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ResultsManagerExplorer/Autodesk.ResultsBuilder.DBApplication.dll
    Autodesk.RouteAnalysis.DBApplication
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/RouteAnalysis/Autodesk.RouteAnalysis.DBApplication.dll
    Autodesk.SteelConnectionsDB
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/Autodesk.SteelConnectionsDB.dll
    Autodesk.StructuralRibbon.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ResultsManagerExplorer/Autodesk.StructuralRibbon.Application.dll
    ConnectedDesktopDB
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ConnectedDesktop/ConnectedDesktopDB.dll
    KeynoteDBServer
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Keynote/KeynoteDBServer.dll
    StraightSegmentCalculationServers
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/MEPCalculation/StraightSegmentCalculationServers.dll
    FittingAndAccessoryCalculationServers
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/MEPCalculation/FittingAndAccessoryCalculationServers.dll
    CollaborateDB
        CodeBase: file:///C:/Program%20Files/Autodesk/Cloud%20Models%20for%20Revit%202021/CollaborateDB.dll
    Autodesk.CivilAlignments.DBApplication.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/CivilAlignments/en-US/Autodesk.CivilAlignments.DBApplication.resources.DLL
    Autodesk.CoordinationModelDB.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/CoordinationModel/en-US/Autodesk.CoordinationModelDB.resources.DLL
    Autodesk.LinkTopography.Parser.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SiteLinker/en-US/Autodesk.LinkTopography.Parser.resources.DLL
    Simulex.Net
        Assembly Version: 2.1.0.0
        Win32 Version: 2.1.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/RouteAnalysis/Simulex.Net.DLL
    Autodesk.RouteAnalysis.DBApplication.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/RouteAnalysis/en-US/Autodesk.RouteAnalysis.DBApplication.resources.DLL
    RevitAPISteel
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitAPISteel.DLL
    ASObjectsMgd
        Assembly Version: 1.0.7345.21938
        Win32 Version: 25.0.32.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASObjectsMgd.DLL
    ASSettings
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASSettings.DLL
    Microsoft.GeneratedCode
    Autodesk.SteelConnectionsDB.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/en-US/Autodesk.SteelConnectionsDB.resources.DLL
    ConnectedDesktopDB.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ConnectedDesktop/en-US/ConnectedDesktopDB.resources.DLL
    Autodesk.DesktopConnector.API
        Assembly Version: 5.0.0.105
        Win32 Version: 5.0.0.105
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ConnectedDesktop/Autodesk.DesktopConnector.API.DLL
    System.Runtime.Caching
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Caching/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Caching.dll
    System.Runtime.Serialization
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
    System.ServiceModel
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
    SMDiagnostics
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
    System.ServiceModel.Internals
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
    System.IdentityModel
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
    StraightSegmentCalculationServers.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/MEPCalculation/en-US/StraightSegmentCalculationServers.resources.DLL
    FittingAndAccessoryCalculationServers.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/MEPCalculation/en-US/FittingAndAccessoryCalculationServers.resources.DLL
    RSCloudClient
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RSCloudClient.DLL
    Autodesk.RevitServer.Management.Client
        Assembly Version: 7.0.0.0
        Win32 Version: 7.0.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.RevitServer.Management.Client.DLL
    Autodesk.RevitServer.Versioning.Client
        Assembly Version: 4.0.1.0
        Win32 Version: 4.0.1.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Cloud%20Models%20for%20Revit%202021/Autodesk.RevitServer.Versioning.Client.DLL
    Autodesk.Bcg
        Assembly Version: 3.26.2.0
        Win32 Version: 3.26.2.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.Bcg.DLL
    Microsoft.Practices.Unity
        Assembly Version: 3.5.0.0
        Win32 Version: 3.5.1404.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Practices.Unity.DLL
    System.Runtime
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.dll
    Microsoft.Practices.Unity.Configuration
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Practices.Unity.Configuration.DLL
    System.Threading
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Threading/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Threading.dll
    System.Collections
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Collections/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Collections.dll
    System.Reflection
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Reflection/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Reflection.dll
    System.Linq
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Linq/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Linq.dll
    System.Globalization
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Globalization/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Globalization.dll
    System.Resources.ResourceManager
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Resources.ResourceManager/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Resources.ResourceManager.dll
    System.Runtime.Extensions
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Extensions/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Extensions.dll
    System.Linq.Expressions
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Linq.Expressions/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Linq.Expressions.dll
    System.Reflection.Extensions
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Reflection.Extensions/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Reflection.Extensions.dll
    Anonymously Hosted DynamicMethods Assembly
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
    Newtonsoft.Json
        Assembly Version: 11.0.0.0
        Win32 Version: 11.0.2.21924
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Newtonsoft.Json.DLL
    DBManagedServices
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/DBManagedServices.DLL
    Autodesk.Bcg.Http
        Assembly Version: 4.1.0.0
        Win32 Version: 4.1.0.51
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.Bcg.Http.DLL
    RSCloudClientRevitService
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RSCloudClientRevitService.DLL
    System.Net.Http
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
    System.Net.Http.WebRequest
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http.WebRequest/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.WebRequest.dll
    System.Net.Http.Formatting
        Assembly Version: 5.2.3.0
        Win32 Version: 5.2.30128.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/System.Net.Http.Formatting.DLL
    Autodesk.Bcg.Net
        Assembly Version: 7.11.5.0
        Win32 Version: 7.11.5.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.Bcg.Net.DLL
    AddInJournaling
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddInJournaling.DLL
    AddInJournalEngine
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddInJournalEngine.DLL
    AddInJournalClient
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddInJournalClient.DLL
    CefSharp.Wpf
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/CefSharp/CefSharp.Wpf.DLL
    FabricationPartBrowser
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Addins/FabricationPartBrowser/FabricationPartBrowser.dll
    Autodesk.UI.Windows
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.UI.Windows.DLL
    RevitAPIUI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitAPIUI.DLL
    UserInterfaceUtility
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/UserInterfaceUtility.DLL
    Autodesk.AppDomainHelper
        Assembly Version: 0.3.3.0
        Win32 Version: 0.3.3.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.AppDomainHelper.DLL
    Autodesk.Fabrication.Lambda.Client
        Assembly Version: 20.0.0.0
        Win32 Version: 20.0.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Addins/FabricationPartBrowser/Autodesk.Fabrication.Lambda.Client.DLL
    SSONET
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/SSONET.DLL
    Autodesk.RevitApplicationHome.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Addins/ModelBrowser/Autodesk.RevitApplicationHome.Application.dll
    CEFRevitUtils
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/CEFRevitUtils.DLL
    Autodesk.RevitApplicationHome.Utilities
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Addins/ModelBrowser/Autodesk.RevitApplicationHome.Utilities.DLL
    APIUIAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/APIUIAPI.DLL
    DesktopMFCAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/DesktopMFCAPI.DLL
    RevitMFCAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitMFCAPI.DLL
    RevitUIAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitUIAPI.DLL
    BuildingSystemsUIAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/BuildingSystemsUIAPI.DLL
    EssentialsUIAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/EssentialsUIAPI.DLL
    EnergyAnalysisUtilitiesAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/EnergyAnalysisUtilitiesAPI.DLL
    DetailUIAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/DetailUIAPI.DLL
    Autodesk.CivilAlignments.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/CivilAlignments/Autodesk.CivilAlignments.Application.dll
    Autodesk.CivilAlignments.Application.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/CivilAlignments/en-US/Autodesk.CivilAlignments.Application.resources.DLL
    Autodesk.CoordinationModelUI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/CoordinationModel/Autodesk.CoordinationModelUI.dll
    Autodesk.FreeFormRebar.DB
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/FreeFormRebar/Autodesk.FreeFormRebar.DB.dll
    Autodesk.FreeFormRebar.DB.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/FreeFormRebar/en-US/Autodesk.FreeFormRebar.DB.resources.DLL
    Autodesk.IFC.Export.UI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Autodesk.IFC.Export.UI/Autodesk.IFC.Export.UI.dll
    Autodesk.LinkTopography.Commands.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SiteLinker/Autodesk.LinkTopography.Commands.Application.dll
    Autodesk.MemberForces.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/MemberForces/Autodesk.MemberForces.Application.dll
    Autodesk.PnIDModeler.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/PnIDModeler/Autodesk.PnIDModeler.Application.dll
    Autodesk.PnIDModeler.Client
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/PnIDModeler/Autodesk.PnIDModeler.Client.DLL
    Autodesk.Precast.Application
        Win32 Version: 21.0.20125.12
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.Application.dll
    Autodesk.Precast.UI
        Assembly Version: 19.0.1.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.UI.DLL
    Autodesk.Precast.RevitBase
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.RevitBase.DLL
    Autodesk.Precast.Base
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.Base.DLL
    Autodesk.Precast.Localization
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.Localization.DLL
    Autodesk.Precast.API
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.API.DLL
    Autodesk.Precast.CNC
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.CNC.DLL
    Autodesk.Precast.CNCExport
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.CNCExport.DLL
    Autodesk.Precast.Commands
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.Commands.DLL
    Autodesk.Precast.Geometry
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.Geometry.DLL
    Autodesk.Precast.RevitGeometry
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.RevitGeometry.DLL
    Autodesk.Precast.RevitUI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.RevitUI.DLL
    Autodesk.Precast.ShopDrawings
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.ShopDrawings.DLL
    Autodesk.Precast.Slab
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.Slab.DLL
    Autodesk.Precast.Wall
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Precast/Autodesk.Precast.Wall.DLL
    Autodesk.ReinforcementNumbering.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ReinforcementNumbering/Autodesk.ReinforcementNumbering.Application.dll
    Autodesk.ResultsExplorer.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ResultsManagerExplorer/Autodesk.ResultsExplorer.Application.dll
    Autodesk.ResultsExplorer.Application.resources
        Assembly Version: 21.0.0.2
        Win32 Version: 21.0.0.2
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ResultsManagerExplorer/en-US/Autodesk.ResultsExplorer.Application.resources.DLL
    Autodesk.StructuralRibbon.Application.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ResultsManagerExplorer/en-US/Autodesk.StructuralRibbon.Application.resources.DLL
    Microsoft.CSharp
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
    Autodesk.Revit.CloudRendering.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Addins/RaasForRevit/Autodesk.Revit.CloudRendering.Application.DLL
    Autodesk.Revit.CloudRendering.Application.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Addins/RaasForRevit/en-US/Autodesk.Revit.CloudRendering.Application.resources.DLL
    Autodesk.Revit.SharedViews.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SharedViews/Autodesk.Revit.SharedViews.Application.dll
    Autodesk.Revit.SharedViews.Application.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SharedViews/en-US/Autodesk.Revit.SharedViews.Application.resources.DLL
    Autodesk.RouteAnalysis.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/RouteAnalysis/Autodesk.RouteAnalysis.Application.dll
    Autodesk.SectionProperties.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SectionProperties/Autodesk.SectionProperties.Application.dll
    Autodesk.SpaceNaming.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SpaceNaming/Autodesk.SpaceNaming.Application.dll
    Autodesk.SteelConnectionsUI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/Autodesk.SteelConnectionsUI.dll
    DotNetRoots
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/DotNetRoots.DLL
    Autodesk.REX.Framework
        Win32 Version: 2021.0.1.4642
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Autodesk.REX.Framework/v4.0_2021.0.0.0__51e16e3b26b42eda/Autodesk.REX.Framework.dll
    AutoLoader
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/AutoLoader/AutoLoader.dll
    ConnectedDesktopUI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ConnectedDesktop/ConnectedDesktopUI.dll
    ContentDelivery
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ContentDelivery/ContentDelivery.dll
    DynamoRevitVersionSelector
        Assembly Version: 2.6.1.8850
        Win32 Version: 2.6.1.8850
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/DynamoForRevit/Revit/DynamoRevitVersionSelector.dll
    DynamoInstallDetective
        Assembly Version: 2.6.1.8786
        Win32 Version: 2.6.1.8786
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/DynamoForRevit/DynamoInstallDetective.dll
    DynamoRevitDS
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/DynamoForRevit/Revit/DynamoRevitDS.dll
    RevitServices
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/DynamoForRevit/Revit/RevitServices.DLL
    Autodesk.DynamoPlayer.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/DynamoPlayer/Autodesk.DynamoPlayer.Application.dll
    EnergyAnalysis
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/EnergyAnalysis/EnergyAnalysis.dll
    FabricationPartBrowser.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Addins/FabricationPartBrowser/en-US/FabricationPartBrowser.resources.DLL
    FittingAndAccessoryCalculationUIServers
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/MEPCalculation/FittingAndAccessoryCalculationUIServers.dll
    FittingAndAccessoryCalculationUIServers.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/MEPCalculation/en-US/FittingAndAccessoryCalculationUIServers.resources.DLL
    KeynoteUIServer
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Keynote/KeynoteUIServer.dll
    PointCloudSnappingServer
        Assembly Version: 1.0.7501.19280
        Win32 Version: mZInternalName
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/PointCloudSnappingServer/PointCloudSnappingServer.dll
    PressureLossReport
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/MEPCalculation/PressureLossReport.dll
    Autodesk.BatchPrint.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Batch%20Print%20for%20Revit%202021/Autodesk.BatchPrint.Application.dll
    Autodesk.BatchPrint.Utilities
        CodeBase: file:///C:/Program%20Files/Autodesk/Batch%20Print%20for%20Revit%202021/Autodesk.BatchPrint.Utilities.DLL
    Collaborate
        CodeBase: file:///C:/Program%20Files/Autodesk/Cloud%20Models%20for%20Revit%202021/Collaborate.dll
    CollaborateBrowser
        CodeBase: file:///C:/Program%20Files/Autodesk/Cloud%20Models%20for%20Revit%202021/CollaborateBrowser.dll
    SkyscraperClientHost
        CodeBase: file:///C:/Program%20Files/Autodesk/Cloud%20Models%20for%20Revit%202021/SkyscraperClientHost.dll
    C4RNET
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/C4RNET.DLL
    eTransmitForRevit
        CodeBase: file:///C:/Program%20Files/Autodesk/eTransmit%20for%20Revit%202021/eTransmitForRevit.dll
    eTransmitForRevit.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/eTransmit%20for%20Revit%202021/en-US/eTransmitForRevit.resources.DLL
    Autodesk.Revit.GenerativeDesign.Application
        Assembly Version: 21.3.9.0
        Win32 Version: 21.3.9.0
        CodeBase: file:///C:/ProgramData/Autodesk/Revit/Addins/2021/GenerativeDesign/Autodesk.Revit.GenerativeDesign.Application.dll
    DotNetEnv
        Assembly Version: 1.0.1.0
        Win32 Version: 1.0.1.0
        CodeBase: file:///C:/ProgramData/Autodesk/Revit/Addins/2021/GenerativeDesign/DotNetEnv.DLL
    Autodesk.WorksharingMonitor.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Worksharing%20Monitor%20for%20Revit%202021/Autodesk.WorksharingMonitor.Application.dll
    Autodesk.WorksharingMonitor.Utilities
        CodeBase: file:///C:/Program%20Files/Autodesk/Worksharing%20Monitor%20for%20Revit%202021/Autodesk.WorksharingMonitor.Utilities.dll
    ExportViewSelectorAddin
        CodeBase: file:///C:/ProgramData/Autodesk/Revit/Addins/2021/ExportViewSelectorAddin/ExportViewSelectorAddin.dll
    FormItConverterRibbon
        Assembly Version: 21.1.19.1
        Win32 Version: 21.1.19.1
        CodeBase: file:///C:/Program%20Files/Autodesk/FormIt%20Converter%20For%20Revit%202021/Addon/FormItConverterRibbon.dll
    AXMImporter
        CodeBase: file:///C:/Program%20Files/Autodesk/FormIt%20Converter%20For%20Revit%202021/Addon/AXMImporter.DLL
    MaterialWrapper
        CodeBase: file:///C:/Program%20Files/Autodesk/FormIt%20Converter%20For%20Revit%202021/Addon/MaterialWrapper.DLL
    ReVVed
        Assembly Version: 2021.1.0.0
        CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/pkhLineworksREVVED.bundle/Contents/2021/reVVed.dll
    WzCtgKTKfWaWsDTLLZLbbaFydgxPA
    log4net
        Assembly Version: 1.2.10.0
        Win32 Version: 1.2.10.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/log4net.DLL
    WPFLocalizeExtension
        Assembly Version: 3.0.1.0
    XAMLMarkupExtensions
        Assembly Version: 1.2.2.0
    Xceed.Wpf.Toolkit
        Assembly Version: 2.7.0.0
    System.Data
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
    System.Data.DataSetExtensions
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
    ReVVed.resources
        CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/pkhLineworksREVVED.bundle/Contents/2021/fr/ReVVed.resources.DLL
    2021Ribbon
        Win32 Version: 1.0.0.01
        CodeBase: file:///C:/Users/MEElizondo/AppData/Roaming/Autodesk/Revit/Addins/2021/RushforthToolsForRevit2021.bundle/Contents/2021Ribbon.dll
    Microsoft.VisualBasic
        Assembly Version: 10.0.0.0
        Win32 Version: 14.8.3752.0 built by: NET48REL1
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    RevitAPIUIMacrosInterop
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitAPIUIMacrosInterop.DLL
    SDACommon
        Assembly Version: 2014.0.0.0
        Win32 Version: 2014.0.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/SDACommon.DLL
    RevitAPIMacrosInterop
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitAPIMacrosInterop.DLL
    AdpSDKCSharpWrapper
        Win32 Version: 2.4.1.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AdpSDKCSharpWrapper.DLL
    System.Dynamic
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
    System.Web.Extensions
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.Extensions.dll
    System.Web
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    Autodesk.RevitApplicationHome.Application.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Addins/ModelBrowser/en-US/Autodesk.RevitApplicationHome.Application.resources.DLL
    PresentationFramework-SystemXmlLinq
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
    RSEnterpriseClientInterop
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RSEnterpriseClientInterop.DLL
    RSEnterpriseClient
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RSEnterpriseClient.DLL
    RS.Enterprise.Common.ClientServer.DataContract
        Win32 Version: 21.0.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RS.Enterprise.Common.ClientServer.DataContract.DLL
    Autodesk.C4R.Client
        Assembly Version: 5.2.0.0
        Win32 Version: 5.2.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Cloud%20Models%20for%20Revit%202021/Autodesk.C4R.Client.DLL
    Autodesk.Revit.Config.Client
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.Revit.Config.Client.DLL
    System.Numerics
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
    AutoMapper
        Assembly Version: 2.2.0.0
        Win32 Version: 2.2.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AutoMapper.DLL
    Polly
        Assembly Version: 6.0.0.0
        Win32 Version: 6.1.2.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Polly.DLL
    netstandard
        Assembly Version: 2.0.0.0
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/netstandard/v4.0_2.0.0.0__cc7b13ffcd2ddd51/netstandard.dll
    Microsoft.Practices.TransientFaultHandling.Core
        Assembly Version: 5.1.1209.0
        Win32 Version: 5.1.1209.1
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Practices.TransientFaultHandling.Core.DLL
    System.Web.Http
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/System.Web.Http.DLL
    Autodesk.JsonApi
        Assembly Version: 9.0.2.0
        Win32 Version: 9.0.2.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Cloud%20Models%20for%20Revit%202021/Autodesk.JsonApi.DLL
    Autodesk.Extensions
        Assembly Version: 9.3.2.0
        Win32 Version: 9.3.2.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.Extensions.DLL
    SSONETUI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/SSONETUI.DLL
    RSCloudClientInterop
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RSCloudClientInterop.DLL
    Autodesk.C4R.Model.Common
        Assembly Version: 5.0.3.0
        Win32 Version: 5.0.3.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.C4R.Model.Common.DLL
    Autodesk.Http
        Assembly Version: 13.0.1.0
        Win32 Version: 13.0.1.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.Http.DLL
    Autodesk.Bcg.Logging
        Assembly Version: 2.4.6.0
        Win32 Version: 2.4.6.25
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.Bcg.Logging.DLL
    Autodesk.RevitServer.Social
        Assembly Version: 1.4.3.0
        Win32 Version: 1.4.3.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.RevitServer.Social.DLL
    CollaborateDB.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Cloud%20Models%20for%20Revit%202021/en-US/CollaborateDB.resources.DLL
    Pubnub
        Assembly Version: 4.0.1.7
        Win32 Version: 4.0.1.7
        CodeBase: file:///C:/Program%20Files/Autodesk/Cloud%20Models%20for%20Revit%202021/Pubnub.DLL
    Autodesk.RevitServer.Storage
        Assembly Version: 2.11.4.0
        Win32 Version: 2.11.4.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.RevitServer.Storage.DLL
    AWSSDK.S3
        Assembly Version: 3.3.0.0
        Win32 Version: 3.3.100.2
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AWSSDK.S3.DLL
    AWSSDK.Core
        Win32 Version: 3.3.100.8
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AWSSDK.Core.DLL
    Castle.Windsor
        Assembly Version: 3.2.0.0
        Win32 Version: 3.2.1.20
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Castle.Windsor.DLL
    Castle.Core
        Win32 Version: 3.2.1.28
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Castle.Core.DLL
    pkhCommon
        Assembly Version: 1.2.0.0
        CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/pkhLineworksREVVED.bundle/Contents/2021/pkhCommon.DLL
    PresentationFramework-SystemData
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
    RevitAPIBrowserUtils
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RevitAPIBrowserUtils.DLL
    RebarUIStartUpAPI
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/RebarUIStartUpAPI.DLL
    Autodesk.ResultsManager.Application
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/ResultsManagerExplorer/Autodesk.ResultsManager.Application.DLL
    Autodesk.SteelConnections.ASRvtFamilyMapping
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/Autodesk.SteelConnections.ASRvtFamilyMapping.DLL
    ASCADLinkMgd
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASCADLinkMgd.DLL
    JointDesignUtils
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/JointDesignUtils.DLL
    ASSettingsMgd
        Assembly Version: 1.0.7345.21391
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASSettingsMgd.DLL
    Acdbmgd
        Assembly Version: 24.0.0.0
        Win32 Version: 24.0.47.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Acdbmgd.DLL
    AsRealDWGLoaderMgd
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/AsRealDWGLoaderMgd.DLL
    Autodesk.SteelConnections.ASRvtModeler
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/Autodesk.SteelConnections.ASRvtModeler.DLL
    ASModelerMgd
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASModelerMgd.DLL
    ASGeometryMgd
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASGeometryMgd.DLL
    System.IO.Compression
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
    ASRepository
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASRepository.DLL
    System.IO.Compression.FileSystem
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression.FileSystem/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.FileSystem.dll
    SqlLocalDbManMgd
        Assembly Version: 1.0.7345.21389
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/SqlLocalDbManMgd.DLL
    ASRepositorySQLSrv
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASRepositorySQLSrv.DLL
    System.Transactions
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
    System.EnterpriseServices
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
    ASNetRuntime
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASNetRuntime.DLL
    ASRepositoryProxy
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASRepositoryProxy.dll
    ASDataObjects
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASDataObjects.dll
    EntityFramework
        Win32 Version: 6.1.40302.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/EntityFramework.DLL
    EntityFramework.SqlServer
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/EntityFramework.SqlServer.DLL
    System.ComponentModel.DataAnnotations
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
    System.Data.OracleClient
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data.OracleClient/v4.0_4.0.0.0__b77a5c561934e089/System.Data.OracleClient.dll
    EntityFrameworkDynamicProxies-ASDataObjects
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/EntityFramework.dll
    ASMgdJoints
        Assembly Version: 1.0.7345.21961
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/SteelConnections/ASMgdJoints.dll
    Autodesk.C4R.Model.Client
        Assembly Version: 1.1.5.0
        Win32 Version: 1.1.5.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.C4R.Model.Client.DLL
    Microsoft.Extensions.Logging.Abstractions
        Win32 Version: 2.2.0.18315
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Extensions.Logging.Abstractions.DLL
    Microsoft.Extensions.DependencyInjection
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Extensions.DependencyInjection.DLL
    Microsoft.Extensions.DependencyInjection.Abstractions
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Extensions.DependencyInjection.Abstractions.DLL
    Microsoft.Extensions.Options
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Extensions.Options.DLL
    Autodesk.Http.DevPortal
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.Http.DevPortal.DLL
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Extensions.Logging.DLL
    Autodesk.Extensions.Json
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.Extensions.Json.DLL
    Microsoft.Extensions.Primitives
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Extensions.Primitives.DLL
    Microsoft.Extensions.Caching.Memory
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Extensions.Caching.Memory.DLL
    Microsoft.Extensions.Caching.Abstractions
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Microsoft.Extensions.Caching.Abstractions.DLL
    Autodesk.Logging
        Assembly Version: 3.0.2.0
        Win32 Version: 3.0.2.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/Autodesk.Logging.DLL
    KeynoteUIServer.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/Keynote/en-US/KeynoteUIServer.resources.DLL
    adui24
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/adui24.DLL
    AdUiPalettes
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AdUiPalettes.DLL
    AdUIMgd
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AdUIMgd.DLL
    OptaneShellExt
        CodeBase: file:///C:/Program%20Files/Intel/OptaneShellExtensions/OptaneShellExt.dll
    SharpShell
        CodeBase: file:///C:/Program%20Files/Intel/OptaneShellExtensions/SharpShell.DLL
    log4net
        Assembly Version: 1.2.15.0
        Win32 Version: 1.2.15.0
        CodeBase: file:///C:/Program%20Files/Intel/OptaneShellExtensions/log4net.DLL
    PinningServiceApi
        CodeBase: file:///C:/Program%20Files/Intel/OptaneShellExtensions/PinningServiceApi.DLL
    System.ComponentModel.Composition
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.Composition/v4.0_4.0.0.0__b77a5c561934e089/System.ComponentModel.Composition.dll
    Autodesk.ProcessPower.P360.Data
        Assembly Version: 2.0.4.0
        Win32 Version: 2.0.4.0
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AddIns/PnIDModeler/Autodesk.ProcessPower.P360.Data.DLL
    PresentationFramework.Luna
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
    Collaborate.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/Cloud%20Models%20for%20Revit%202021/en-US/Collaborate.resources.DLL
    System.Security
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
    AWSSDK.SecurityToken
        CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202021/AWSSDK.SecurityToken.DLL
    2021Bridge
        CodeBase: file:///C:/Users/MEElizondo/AppData/Roaming/Autodesk/Revit/Addins/2021/RushforthToolsForRevit2021.bundle/Contents/2021Bridge.dll
    System.Management
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    2021AddIns
        Win32 Version: 1.0.0.02
        CodeBase: file:///C:/Users/MEElizondo/AppData/Roaming/Autodesk/Revit/Addins/2021/RushforthToolsForRevit2021.bundle/Contents/2021Addins.dll
    Microsoft.mshtml
        Assembly Version: 7.0.3300.0
        Win32 Version: 7.0.3300.0
        CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
    Accessibility
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    Microsoft.Office.Interop.Excel
        Assembly Version: 15.0.0.0
        Win32 Version: 15.0.4569.1506
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.Office.Interop.Excel/15.0.0.0__71e9bce111e9429c/Microsoft.Office.Interop.Excel.dll
    office
        Win32 Version: 15.0.4613.1000
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/office/15.0.0.0__71e9bce111e9429c/office.dll
    CustomMarshalers
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
    PresentationUI
        CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    May 14, 2012
    509
    04:19 PM
    What are you trying to do when you get this message?
  8.    #8
    September 29, 2020
    5
    05:19 PM
    Trying to import views from a linked Architectural model.
  9.    #9
    3,205
    03:19 PM
    What kind of view and what "tool" are you using?
    FWIW, It isn't "normal" to import a view from another model. If an arch model has a section in a location you want we create a section in our own model in the same location. We can optionally override Visibility/Graphics to use the By Linked View option so we see see annotation and model elements based on their section view's configuration.
  10.    #10
    4,475
    10:19 PM
    My money is on it being a perspective view.
    There are ways.
    Dirty copy pasta:
    https://revitforum.org/showthread.ph...her-file/page2
    Deep diving:
    https://outputbuilding.wordpress.com...field-of-view/
    It's nowhere near as easy as it should be .
  1. ETABS - Importing Revit Model
    By sdijan in forum Structure - Interoperability
    Last Post: November 9th, 2017, 11:50 AM
  2. Importing views from another project. Which way is recommended?
    Last Post: August 6th, 2015, 02:04 AM
  3. Copy/monitor slanted column from Struct model to Arch model!?
    Last Post: January 13th, 2015, 05:21 PM
  4. Importing UB's and UC's into model
    By stryder444 in forum Structure - General Questions
    Last Post: October 28th, 2014, 09:55 PM
  5. Structure model vs arch model - cutting
    Last Post: November 13th, 2011, 02:03 AM
