Results 1 to 10 of 11
Thread: Upgrading Models with CLOSED Worksets
    Member aperte's Avatar
    99
    10:27 PM
    Previous upgrade posts haven't really addressed this - hoping someone has encountered this.
    I have some very old (and very large) project models that attempts to upgrade have taxed out the processing on our standard workstations. I'm outlining best practices and aside from the advice to upgrade any LINKED models first, to avoid temporary upgrading of them during the main file upgrade, I'm weighing advising to CLOSE ALL WORKSETS other than some lightweight ones (Shared Levels and Grids, for instance) during the initial upgrade, and then open those worksets incrementally.
    Does anyone have experience with this as an upgrading workflow, and can confirm/deny that this improves performance/stability during the upgrade?
    11,307
    12:27 AM
    Quote Originally Posted by aperte View Post
    I cant speak to *stability* issues, as i havent ever experienced any INstability with upgrading, and i do a lot of it.
    My concern/curiosity about only opening some worksets incrementally, is: They all have to be opened at some point in the upgrade process, or i would FEAR that Revit hadnt "done its stuff" to those elements. That might not be true at all, though. Id be curious to get the take of someone in development, on that.
    But it would also take WAY longer, to fuss around with it. I think i would just tell management the computers werent up to the task, lol. Hardware is cheaper than time, in cases like these.
    3,403
    12:27 AM
    Since many times, individual models are linked into each other in both directions, I usually rename all the models by adding an X to the file name (in Windows Explorer)
    Then as I start upgrading models (Links first), I rename one file to the correct name, and open/upgrade it.
    Then I move on to open & upgrade the next.
    Working my way up the Link tree, eventually by the time you get to the top file model, all of the Links have been upgraded and should behave.
    Renaming the files prevents them from loading, but retains everything (V/G settings). It will just report Not Found.
    You may need to go back into some models and Reload, but that can be done once everything is upgraded.
    Also, renaming all of the models helps keep track of which ones are completed.
    Since this entire process can take hours, I tend to get distracted easily and start working on something else while I'm waiting.
    11,307
    12:27 AM
    We do this as well, but not with an X: The version number is at the end of the File Name, for us.
    So 20057-Arch-R19 gets renamed to 20057-Arch-R21, if im upgrading it to 2021. It auto stops the links, as you mentioned. Then i reload them after theyve been upgraded.
    99
    10:27 PM
    Good point, but $$ in the age of COVID is.... under lock and key.
    99
    10:27 PM
    Thanks for this tip, Dave. I use the 'add an X' method to a LOT of processes (mostly family and group related) so I like this method as it's in sync with other process recommendations.
    99
    10:27 PM
    Okay, I'm going to time test upgrading a model both with all worksets open and with closed/re-open. I've got a VPN/RDP situation, so it may not be a 'pure' result, but we'll see.
    Thanks for your input, guys, appreciate having a soundboard.
  8.    #8
    Long Beach, CA
    243
    10:27 PM
    Hahaha. Yep. That seems to be an issue most everywhere. I hopeful for the day when that stops being a veiled excuse for not spending money.
    Jon
  9.    #9
    June 14, 2011
    CT, USA
    641
    01:27 AM
    Quote Originally Posted by kingjosiah View Post
    Wow... On so many levels, just wow.
  10.    #10
    11,307
    12:27 AM
    Jon
    Im always hopeful for a day when AE firms realize that "their employees burning time trying to find workarounds derived from having substandard gear" is the same (or more) money lost than the price tag for equipment or tools to do the job right, but that continues to be my wish.
    I laugh when clients tell me they cant afford to spend an extra 500-1000 dollars on a mchine for a member of the staff, when the difference in performance is so staggering its costing them hours per week. Hehehe.
  1. How do i change worksets for my Linked Models
    By electricalnewbie in forum MEP - General
    Last Post: September 23rd, 2020, 10:27 PM
    Last Post: November 13th, 2017, 12:15 AM
  3. Linked Models/CAD and Worksets
    By wwdreamb in forum Architecture and General Revit Questions
    Last Post: August 24th, 2017, 07:15 AM
  4. Wierd room bounding in closed worksets problem
    By josephpeel in forum MEP - General
    Last Post: December 10th, 2014, 10:46 AM
  5. Linked Models & Worksets
    By kirklyncox in forum Architecture and General Revit Questions
    Last Post: May 21st, 2014, 05:04 AM
