Thread: Line Spacing For Dimension Text
    September 14, 2020
    7
    12:33 PM
    Hi all,
    I have been having issues where I can't find how to tighten/squeeze my text boxes in dimensions closer to the dimension line. Is it possible to manually do this via edit type or edit family? For example, I want the upper and lower dimension text box to be 1/16" from the dimension line. Also, when I manually pull and drag the dimension text, is it possible to delete the curved line that comes with it? Thank you
    Edit:
    Also, is it possible to stack texts in a dimension text. Thank you
ID:	39525   Click image for larger version.
    Member duende123's Avatar
    November 20, 2015
    238
    03:33 PM
    the curved line
    Stack.....
    mmmmm.....
    maybe....
    September 14, 2020
    7
    12:33 PM
    Thank you for the responses duende123,
    I am still having trouble where when I changed my text offset from 1/8" to 1/32" for example, both the top and bottom text shift down, where I want the lower text to shift up closer to the center line.
ID:	39535Click image for larger version.
    Also, unsure what the technical term is, but when I have a long dimension text with 6,7,8, etc. words in the "below" Text Field , I want to stack 3 words on top of 3 words, 4 words on top of 4 words, etc. Thank you
    November 20, 2015
    238
    03:33 PM
    No way!!!
    Text Offset = 0 is the minimum distance between the text above and below.
    if you move the text manually the whole set moves
    And, it seems to me that only three levels of texts are possible in a dimension.
  1. Spacing multi line text......how??
    By donks in forum MEP - General
    Last Post: July 30th, 2018, 05:13 PM
  2. Change Text Height of Text Below Dimension Line
    By nod684 in forum Architecture and General Revit Questions
    Last Post: March 8th, 2016, 05:58 AM
  3. sheet issue / revision Schedule spacing & line spacing problem
    By Mrjessehlee in forum Architecture and General Revit Questions
    Last Post: June 17th, 2014, 01:05 AM
  4. Text line spacing
    By caseym in forum Architecture and General Revit Questions
    Last Post: March 7th, 2014, 01:49 AM
