Thread: Project template management rte vs central model as template
    December 11, 2010
    Astana
    261
    08:52 PM
    Hi everyone,
    What do you use: project template (rte) or central model as a template and why?
    I am thinking of switching to using the central model due to fewer steps when creating a new project::
    Project template: New project, save, create worksets (plugin or Dynamo required), save, sync.
    Central model as template: Open & detach, save as, sync.
    I can also manage worksets without additional tools.
    Are there any pitfalls in using the central model as a template?
    Please share your experience.
    Member duende123's Avatar
    November 20, 2015
    238
    10:52 AM
    If those who use it master the process to create new central models, no problem.
    If not, keep a separate copy. Just in case...
    11,298
    09:52 AM
    2 Not allowed! Not allowed!
    Hi everyone,
    I would Write Protect the directory you store it in, lest you experience someone forgetting to do DFC and wrecking your Template.
    We use a normal template here. Then again, we dont need many worksets at all, so setting them up is basically 3 minutes. No upside to a workshared starter-project, for us.
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    269
    02:52 PM
    I use central models with placeholders for my linked files, so i only need to reload from, and still all my viewtemplate are fine.
    11,298
    09:52 AM
    Quote Originally Posted by Marcel Jansen View Post
    You can do that with an RTE as well.
    December 11, 2010
    Astana
    261
    08:52 PM
    Thanks for your replies!
    It looks like I can use project template or central model as a template without big problems, however I decided to stay with the project template because:
    There is a chance of messing up the central model - template by forgetting to detach (extra precautions required).
    Creating a new project from a project template is familiar to users and does not require additional instructions. it's better to stick to standard actions.
  1. Choosing the right template. Face based template over floor based template
    By sabari2504 in forum Architecture and General Revit Questions
    Last Post: April 11th, 2017, 02:56 PM
  2. Copy and Paste an MEP model into new project template.
    By andyrh1982 in forum MEP - General
    Last Post: July 9th, 2015, 03:25 PM
  3. Moving a model into a template
    By sstringint in forum Structure - General Questions
    Last Post: February 12th, 2014, 04:11 PM
  4. Schematic template vs. general purpose template + workflow (long winded post, sorry)
    By kpcarch in forum Architecture and General Revit Questions
    Last Post: September 10th, 2013, 07:27 AM
  5. Object Styles Spreadsheet for Template Management
    Last Post: April 28th, 2011, 01:48 PM
