Thread: Create mass based on iclined work plane
    October 1, 2020
    4
    09:29 PM
    Hello.
    Any one know how to create an extrusion mass with its base is on an inclined plane? I need to create a beams sisten of an old barn where his beams are not equal and straight like its showing in the imagen. I dont know if its possible to use the inclined plane as a base or any other ideas how to do it.
    Thanks in advance.
Name:	Irregular beams.JPG
    December 11, 2010
    Astana
    261
    01:29 AM
    Create a named inclined reference plane and set as the Work Plane
    Create an extrusion
    Tip: Beams also can follow a sloped work plane.
    975
    05:29 AM
    named reference planes are your friend in this case.
    There are some elements that will not host to sloped work planes but in general most will, as Nurlan mentioned you have to define the work plane before creating the object concerned that needs to be hosted to the sloped plane.
    Only named reference planes will show in the list of planes you can choose as work planes.
    October 1, 2020
    4
    09:29 PM
    Thank you very much both of you. That works.
  1. Work Plane based Families...
    By Tomcsie in forum Architecture - Family Creation
    Last Post: August 11th, 2020, 02:49 PM
    Last Post: November 30th, 2019, 05:45 PM
  3. Work Plane Based- Doesn't always host
    Last Post: February 23rd, 2018, 02:45 PM
  4. Wishlist - Right-click on named reference plane, set as work plane.
    By ryntau in forum Architecture - Family Creation
    Last Post: September 22nd, 2015, 04:30 PM
  5. Unhosted Families versus Unhosted "Work Plane Based" families.
    By Twiceroadsfool in forum Architecture and General Revit Questions
    Last Post: July 25th, 2011, 02:42 PM
