Results 1 to 9 of 9
Thread: Linked autocad drawings in revit models
    September 21, 2020
    10
    12:50 PM
    I'm modelling in Revit a commercial project, but the information is in autocad. I link every floor from autocad in the revit model. But some autocad drawings don't show properly.
    The autocad drawings also have references, and that is the problem some references don't show properly in the revit model. I'll try relink again all the references in Autocad, save and reload in Revit but I still have the same problem.
    I don't know if there's a problem with that workflow is the first time I had seen that problem.
    If anyone can bring me the light I'll appreciate, thanks.
    Member scourdx's Avatar
    July 4, 2013
    83
    09:50 AM
    What info are you having issue with? Here are couple of issues with CAD I've experience
    1. If you have override color & linetype in AutoCAD, it won't allow you to override them in Revit. So always make sure all objects are set to bylayer.
    2. MTEXT is a big issue because people love to use the text editor and start changing the text justification and formatting. When link into Revit, the text will jump to other places.
    3. Pline Width is pointless. In Revit it won't display any polyline thickness regardless if you want to make a thick line.
    4. AutoCAD Hatch set to small will turn to solid color in Revit. This is especially issue if you are inserting manufacturer block. Increase your hatch scale.
    5. XLINE, MLINE, RAY, gradient Hatch & custom linestyle won't display in Revit.
    6. AutoCAD object with material won't get transfer over to Revit even if they both shared the same identical material. I'm not sure why Autodesk won't let it translate from one product over the other. You are always stuck with Render-000-000-000 material.
    7. The AutoCAD SOLID object type will not respect Revit transparency graphic override.
    8. XREF AutoCAD drawing will cause lines to jump and be fuzzy. Often I have to resort to binding all the XREF to make it show up correctly.
    There are many. I will add more if I recall other one.
    2,831
    02:50 AM
    Not really adding much to the convo, just wanting to say that it a lot of issues!
    can you bind references in autocad like with links in revit?
    June 14, 2011
    CT, USA
    641
    12:50 PM
    Instead of relying on nested links, link every file into the model separately.
    July 4, 2013
    83
    09:50 AM
    Yup...however AutoCAD binding is another different can of worms. There are two type of binding - Bind-Bind and Bind-Insert.
    Bind-insert will combine same layers into one and you will see more object. However if the block have the same name, it will override them and you will get weird drawing graphical issue. This keeps the file size smaller
    The bind-bind is the best result but you will get huge list of layers. This is a common problem and you will see layers, linetype and blocks with $0$. Also file size can be huge and very heavy.
    September 21, 2020
    10
    12:50 PM
    My problem is some of the xref don't show 8n the revit model but in autocad don't have any problem
    September 21, 2020
    10
    12:50 PM
    The issue with that is they use the same xref in too many drawings, and I don't see that suitable, thanks any way, if I can't solve the problem I think In gotta do that.
  8.    #8
    July 4, 2013
    83
    09:50 AM
    2 Not allowed! Not allowed!
    Quote Originally Posted by Luis94 View Post
    Check and see if those XREF is set to overlay. If it is, it won't show in Revit. Nested XREF in AutoCAD will create issue inside Revit. You have to make sure a lot of the XREF don't have unloaded, unreference or Not Found. If they do, Revit won't show the CAD properly. Most often I recommend just bind it to keep yourself from headache. Keep it simple and you won't run into issue.
  9.    #9
    September 21, 2020
    10
    12:50 PM
    Thank I think is the better way, I'll gonna check that, thanks
  1. Separating the models and the drawings
    By ocrender in forum Architecture and General Revit Questions
    Last Post: February 8th, 2017, 10:27 PM
  2. How to Import Line Weights from AutoCAD when Linking drawings into Revit
    By j2mattones in forum Architecture and General Revit Questions
    Last Post: November 19th, 2014, 03:18 AM
  3. What Revit Wants: Thoughts on Models vs Drawings
    Last Post: September 26th, 2012, 06:18 AM
  4. Can i import autocad drawings and make MEP for it ?
    By ahmed_hassan in forum MEP - General
    Last Post: March 25th, 2012, 02:02 PM
  5. Referencing Revit models in Autocad drawings
    By Nick Kane in forum Architecture and General Revit Questions
    Last Post: August 4th, 2011, 04:39 PM
