Thread: Interior Wall Sweep
    September 14, 2020
    7
    01:17 PM
    Interior Wall Sweep
    Hi all,
    I am having trouble inserting an interior wall sweep for a restroom I created and would love some help please. First, I created a profile for the "Coved Wall Sweep" using materials: rubber for the base of the wall and wall sweeped it on my wall. However, it originally came out on the exterior wall.
    Therefore and up to speed...
    I created a new profile of the same exact sweep and mirrored it across the y axis and offset it a negative distance so it aligns it on the interior wall.
    Now I am getting this error (attachment below) and do not know how to proceed with creating an interior wall sweep from a profile. Thank you.
    975
    06:17 AM
    Check your wall joins at intersections it may be the way the walls are joining, if you set them to mitre will it fix this issue?
    Also no need to change the profile position just change the justification of your wall and it will flip the profile. If you justify exterior/interior it will depend how you place the wall as to where it defines the profile position (example with "exterior" justification) If you draw from right to left on the screen and left to right on the screen you will see that each different way of drawing the wall changes the exterior face location. Same with up/down vs down/up on the screen.
    Of course this has implications if you go changing wall thickness, so be sure you choose the right justification for possible changes (and profile location) You might find you need one wall of each type with a profile on each different side to deal with different justifications.
  1. Wall sweep on an angled wall (modified wall profile)
    Last Post: June 5th, 2018, 08:54 PM
  2. Wrap wall sweep at wall opening on a continuous wall
    Last Post: April 27th, 2018, 09:13 PM
  3. Host Wall Based Object on furred out wall (interior surface)
    Last Post: August 7th, 2017, 04:13 PM
  4. create a wall sweep on an angled wall (gable end wall) (2017)
    Last Post: August 3rd, 2016, 06:34 PM
  5. Is there an advantage to using a wall sweep as opposed to an in-place family sweep?
    By cnd in forum Architecture and General Revit Questions
    Last Post: September 14th, 2015, 08:16 PM
