Thread: Am I no longer able to trim the Revit Packages through the INI file?
    Member Markus's Avatar
    July 27, 2012
    Seattle, WA, United States of America
    347
    08:48 AM
    I thought I could avoid installing Formit, all the material libraries, ADSKAPP, etc. by editing the INI file identified in the deployment shortcut (I can reduce the deployment image by several gbs). I have done that for older builds of Revit, but I now get an error message with Revit 2021 when I "Create & Modify a Deployment" in the Tools subfolder. Is there another text file I need to hack?
    e.g. i would remove the items from the UI_Sequence, and then comment them out.
    UI_SEQUENCE=BeginDeploymentDlg;LicenseDlg;ProductI nfoDlg;ProductSelectionDlg2;ADSKLICENSING;RVT;FORM IT;MEP_FAB_IMP;
    #=====CMILM2021;CMPLM2021
    11,300
    10:48 AM
    Quote Originally Posted by Markus View Post
    I thought I could avoid installing Formit, all the material libraries, ADSKAPP, etc. by editing the INI file identified in the deployment shortcut (I can reduce the deployment image by several gbs). I have done that for older builds of Revit, but I now get an error message with Revit 2021. Is there another text file I need to hack?
    Are you talking about with the original Revit 2021 deployment from earlier this year, or with the new format one, downloaded after 2021.1?
    July 27, 2012
    347
    08:48 AM
    The original deployment.
  1. Revit + Signage Packages. Thoughts?
    By nharburger in forum Architecture and General Revit Questions
    Last Post: January 14th, 2020, 09:43 AM
  2. Revit no longer creating PCP files
    By Grumple in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2016, 02:15 PM
    Last Post: November 23rd, 2015, 03:45 AM
    Last Post: January 20th, 2014, 03:16 AM
    Last Post: May 20th, 2013, 06:16 AM
