Thread: 3D view linework graphics issue
    February 4, 2016
    5
    12:57 PM
    The other day revit started showing my 3D view with super fat lines. See pictures below. The first is with line weights turned off, the second on. Graphic display silhouettes are off. Any thoughts?&nbsp;<br>Click image for larger version.
Name:	lines turned off.PNG
Name:	fat lines.PNG
    11,303
    02:57 PM
    Quote Originally Posted by vkmultra View Post
Name:	fat lines.PNG
    If that is a Camera/Perspective, select the Crop Region, and Click Edit Size in the ribbon, and let us know how big the image is.
    If its an Axon/Default 3D View, what scale is it set to?
    February 4, 2016
    5
    12:57 PM
    It's a default 3d view set to Perspective. Not sure I know how to adjust the scale of default 3D.
    11,303
    02:57 PM
    If its a perspective, turn the crop region on, and select it. Then click Edit Size in the Ribbon, and tell us what the size settings are.
    February 4, 2016
    5
    12:57 PM
    Width 5 7/8" height 3 3/16"
    February 4, 2016
    5
    12:57 PM
    I have never looked at the cropped size view for the default 3D view. Can this also impact 3d navigation movement and speed? (pan, orbit, zoom etc) Moving around in Revit is never as nice and easy as Rhino, sketchup and enscape for example....
    February 4, 2016
    5
    12:57 PM
    I increased the scale and that worked!
  8.    #8
    11,303
    02:57 PM
    Awesome! I was away at lunch. Sorry. Yeah, that view is tiny, basically. So the lines appear thick and huge. Making the view bigger, the lines appear to be smaller, of course.
    When Revit makes Perspectives, for some reason they start out super small. ive never understood why.
  1. View Range, Visibility Graphics & Wall Opening Tool issue help in RST 2014
    By Kyle Roseman in forum Structure - General Questions
    Last Post: November 6th, 2014, 11:20 PM
  2. Linework issue
    By tjbota in forum Architecture and General Revit Questions
    Last Post: August 8th, 2014, 07:41 PM
  3. 2014: Issue with Linework Tool on Transparent Slab...
    Last Post: July 9th, 2014, 02:07 PM
  4. Remove 'Linework Work' From a View?
    Last Post: May 24th, 2012, 04:53 PM
  5. Graphics Issue
    Last Post: April 14th, 2011, 08:17 PM
