Thread: Host family to multiple objects?
    November 15, 2017
    66
    09:55 PM
    I have a floor based floor drain family with a void that cuts the floor. I need to place the drain in the middle of two adjacent floors but since I can only host the family to one of the floors, only of them gets cut by the void. As a result half the drain looks good and half of it gets overlapping lines as the floor beneath it isn't cut. Is this possible to achieve without adding separate voids in place?
    Also. The floors have a slab edge profile which doesn't cut either, even in the floor hosting the family.
    Member duende123's Avatar
    November 20, 2015
    238
    03:55 PM
    Are the floors joined?
    In floors I'm not sure, but in walls, families cut both if they are united
    11,303
    02:55 PM
    2 Not allowed! Not allowed!
    Instead of hosting, having an unhosted family with Voids in it, and setting it to Cuts with Voids, will allow you to cut several objects, with that component.
    November 15, 2017
    66
    09:55 PM
    Quote Originally Posted by duende123 View Post
    I need the line between the floors to be visible so I can't join them
    This worked well, thank you!
  1. Replies: 1
    Last Post: September 30th, 2016, 03:33 PM
  2. Selecting multiple objects
    Last Post: July 13th, 2016, 02:54 PM
  3. Lighting Family - Face Host, Adding multiple light sources, Best Practices
    By Orbik in forum Architecture - Family Creation
    Last Post: December 15th, 2015, 03:37 PM
  4. Locking the origin of a line based family in the host family
    By Karzan in forum Architecture - Family Creation
    Last Post: April 1st, 2015, 09:30 PM
  5. flex multiple objects?
    By Dave Jones in forum Architecture - Family Creation
    Last Post: January 23rd, 2012, 12:17 AM
