Thread: Attaching hanger to pipes
    June 17, 2014
    Lyon
    10
    03:52 AM
    Hi
    I try to build a hanger family that would be attached to pipes and in a second time adjusted to the support (ceiling, wall or floor).
    I can build complicated families but I don't know MEP world
    So I start with a pipe (duct) accessory with two linked connectors glued back to back (d=0).
    It works but I find it a little weird because it cuts pipes... The goal would be to benefit from the Revit calculation possibilities in following processes.
    Is it a good solution ?
    June 14, 2011
    CT, USA
    678
    09:52 PM
    Why have connectors in a hanger family? It doesn't make sense unless you want to "cut" the pipes.
    June 17, 2014
    Lyon
    10
    03:52 AM
    The goal is to insert the family on the pipes, moreover the ring can get the pipe diameter.
    But the drawback is that it cuts the pipe indeed ..
    Forum Addict
    1,046
    12:52 PM
    Magicad already has a plugin for pipe supports and ventilation supports, and cable trays.
    I am pretty sure their family is ceiling face based and does not contain connectors, but it calculates height and placement from the radius of the pipe and the placement relative to ceiling above. No idea how it works but it does work very nicely.
    June 17, 2014
    Lyon
    10
    03:52 AM
    Thanks, it looks fine but I can't impose this solution to the firm.
    I have made what you describe (support or hanger adjusted to the duct) based on a 2level GM.
    An alternative could be based on the duct (my question) but I don't know if the fact that the duct is cutted by "nul" accessories (ie with 2 connectors glued back to back) is a problem or if it's "transparent" in flood calculations, this is my question.
    June 14, 2011
    CT, USA
    678
    09:52 PM
    I'm almost positive that you shouldn't have any connectors in the hanger family as it is not a part of the air system.
  1. Hanger Family
    By swooll3 in forum MEP - Family Creation
    Last Post: December 16th, 2018, 05:42 PM
  2. Hanger Schedule
    By swooll3 in forum MEP - General
    Last Post: October 17th, 2017, 12:11 PM
  3. Bottom Of Hanger
    By mpwolfe in forum MEP - General
    Last Post: June 27th, 2016, 07:00 PM
  4. Replies: 8
    Last Post: November 8th, 2013, 09:07 PM
  5. Hanger Columns
    Last Post: August 9th, 2013, 09:26 AM
