Thread: Creating a "drop-down" property in Revit
    October 15, 2020
    05:56 PM
    Question Creating a "drop-down" property in Revit
    I am quite new to Revit and I have a question regarding a creation of custom property for objects.
    I would like to have a property which can accept values from a certain predefined list (like a dropdown menu in forms).
    Is it possible?
    Regards,
    Asaf
    2,833
    12:56 AM
    I think you'll find that revit will populate drop down options with existing values. IE some element has a value, some other element has a different value. Click and start typing to enter a new value will search the existing values and offer those in the drop down. If your entry doesn't exist the drop down will be blank, but if you create your new value it will become available for future choices, like a search bar reading your valid history.
    Then there are family type parameters which populate from existing loaded families, from what is available in your project (or family if in editor).
    Then there are type catalogues, displaying all options from a text file.
    If none of that helps you'll have to be a bit more specific with your question.
    October 15, 2020
    05:56 PM
    Some clarifications
    Thanks a lot.
    The idea is that I want to define some environment definitions that will be published to all the employees.
    For several text field, I don't want the user to be able to insert any text, but several specific predefined options.
    December 23, 2019
    10:56 AM
    Quote Originally Posted by asaf View Post
    Thanks a lot.
    Sounds like there is some potential for a key schedule to be used that fills out fields for elements. Build your predefined key schedule with the values you want as options, and then use the key as your drop-down to fill out the appropriate parameters.
    Member duende123's Avatar
    November 20, 2015
    238
    10:56 AM
    Which does not prevent a user from writing whatever he wants. But...
    3,398
    09:56 AM
    I doubt this is what you really want, but here's another way to have a limited list
    https://forums.autodesk.com/t5/revit.../idi-p/7663700
    (And go up-vote the Idea while you're there.)
  1. creating pattern in revit "solution "
    By archsaad in forum Architecture and General Revit Questions
    Last Post: May 16th, 2017, 04:51 AM
  2. Add property "Building Number" in Revit Architecture and export to Ifc file
    By RobSSS777 in forum Architecture and General Revit Questions
    Last Post: April 13th, 2016, 01:24 PM
  3. Creating custom windows-category with "pre-cut in plan" check-box
    By Knall in forum Architecture - Family Creation
    Last Post: November 20th, 2014, 02:00 PM
  4. Rebar Diameter symbol "" is Showing as "0" in Revit 2014
    By Shefypattambi in forum Architecture and General Revit Questions
    Last Post: July 14th, 2014, 01:49 PM
  5. "Show In" Property question
    Last Post: February 20th, 2012, 02:23 PM
