Thread: Exported Ifc not transparent
    May 19, 2012
    84
    07:13 PM
    I export revit-model which contains the families (shared) and with some model groups (exists of glass as material). Weeks long the exporting to IFC is perfect. I see the ifc model with transparent object. Also the model group (made from glass material) (see pict left side).
    Since 3 days ago the exporting goes wrong: the shared families look good as normal, only all the model groups are non transparent. I don't know whether I ever changed the setting accidentally. (see pict right side)
    Question:
    How can I fix that the exported IFC model contains transparent model groups again?
    Kind regards,
    peter smith
    Last edited by peter smith; October 17th, 2020 at 07:32 PM. Reason: message shorter
    Member scourdx's Avatar
    July 4, 2013
    83
    12:13 PM
    Do you use OOTB Revit IFC export? Did you use high detail export instead of low detail. I find their export isn't 100% translate well. You can try using ArchiCAD IFC export from Revit. Most often I find this method export model much better than OOBT Revit
    https://graphisoft.com/downloads/interoperability
  1. Color exported ifc file
    By peter smith in forum Architecture and General Revit Questions
    Last Post: June 2nd, 2018, 03:53 PM
  2. Changing the origin of your exported DWG
    By hroark in forum Architecture and General Revit Questions
    Last Post: December 7th, 2012, 05:57 PM
  3. Exported Sheet DWG issue!
    Last Post: April 18th, 2012, 06:21 PM
  4. Doubling up of DWG when exported
    Last Post: January 20th, 2012, 05:30 PM
  5. Transparent Glass not transparent in Section View
    By Elisa in forum Architecture and General Revit Questions
    Last Post: December 17th, 2010, 05:02 PM
