Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: Collaborate on a Revit Central File
  1. #31
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    288
    05:41 AM
    so the cheapest solution and tiime saving (Revit server seems to be woooww!!) is Bim 360?
    Phil
  2. #32
    11,559
    10:41 PM
    Quote Originally Posted by philsogood View Post
    Phil
    Revit Server is the "cheapest" if you are only talking about Hard Costs in software, and you arent talking about Soft Costs of: IT Labor for setup, IT Software (needing extra OS's for RS Accelerators), potentially needing extra hardware for RS Accelerators, IT Labor for maintenance time, Production Staff labor for uploads/downloads, Production Staff labor for Consultant Coordination (unless you hack it (unsupported), Consultants cant get in your RS unless you use something like Clarity overlayed on top of RS< or hack the heck out of your RS and make it public facing (i dont recommend this, its a risk).
    Otherwise, yes: BIM 360 is the cheapest way to collab from multiple locations or multiple companies.
    VDI is an option (mainly just for single companies with multiple locations) but its damn expensive and damn time consuming to set up (and get right) when you are just starting. Its not something you *pivot* too.
  3. #33
    Member Marcel Jansen's Avatar
    December 26, 2011
    The Netherlands
    296
    05:41 AM
    First i used revit server and that worked really nice.
    We now switched to a central model on a share on a nas (don't ask me why) and it does work without crashing. It is slow*, but i never thought it would work this way without crashing.
    Worksharing monitor helps a lot so we don't synch at the same time.
    *revit server synching with 500Mbit was <1min, and now with a share on a 100mbit fiber it takes >10 mins.
    I jinxed it it worked for 3 days, i hope we will return to the revit server soon.
  4. #34
    December 28, 2020
    10:11 AM
    Revit Server
    Hi All
    I'm looking to understand some nitty gritty of Revit Server. Our organization is exploring using Revit Server as network based file sharing and collaboration has been proving cumbersome with everyone working from home. Can some one provide me tips on Revit Server basics such as what should I be considering to prove its worth before proposing to the business. Just trying to figure out points to address for a good business case. Thanks in advance!
  5. #35
    3,490
    10:41 PM
    Revit Server really isn't going to help much with Working From Home.
    RS was designed to allow collaboration on a Revit model between two office in the same company.
    Grossly over simplified, but in nutshell, you have a server running Revit Server in each office, and RS synchs the Central file (and element borrowing) between offices.
    While there are ways to trick RS into thinking you have an RS server on your home computer, that's not what it was designed for.
    And there is a lot of stuff happening in the background even after you've closed Revit.
    So it may seem like you're done syncing you Central file, but RS might still be running for many minutes after.
    There are also setup and maintenance costs associated with RS.
    RS may seem cheaper at first glance, but you'll probably suck up in maintenance time and lost files what you'd pay for BIM 360, which is a far more advanced (modern) software and has been designed for what you're trying to do.
  6.    #36
    February 13, 2021
    05:41 AM
    Quote Originally Posted by Karalon10 View Post
    I personally think BIM360 is a better platform as there are also coordination and collaboration tools as well.
    ProjectWise is another choice but I do not think it allows worksharing.
    I think the platform of choice in Australia for some time was ACONNEX but I have no idea if this supports workshared revit files, I have a feeling that it is mostly just a check in/out type doc system more for AutoCAD and other DOCS than RVT worksharing.
    I would also mention Accruent Meridian as an option that supports worksharing.
    If you just want to share for review, then you could use website 3dpackages.com
  1. Revit LT for central file?
    By paidpal in forum Architecture and General Revit Questions
    Last Post: March 27th, 2019, 10:36 PM
  2. Revit local recovery file significantly smaller than central file after crash
    By techtonic in forum Architecture and General Revit Questions
    Last Post: January 25th, 2017, 10:58 PM
  3. Central file/local file - working from home
    By nick_h in forum MEP - General
    Last Post: May 5th, 2016, 02:22 PM
  4. Revit 2015 File - Auditing Local or Central File Leads to Message Stating:
    By nick.atal in forum Architecture and General Revit Questions
    Last Post: May 12th, 2015, 11:13 PM
  5. Different Revit Versions with a Central File??
    By tzframpton in forum Architecture and General Revit Questions
    Last Post: December 21st, 2011, 11:13 PM
