Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Equivalent node
  1. #11
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    428
    12:06 PM
    Remove those first 2 nodes and just make a list with the same string names as in your column A of the excel. ["Windows", "Doors", etc]
    That should get you past this hurdle. The rest of that script looks pretty convoluted so unsure if it is actually going to work. The template things you're testing are completely irrelevant.
    And to repeat myself, if you're learning this on Dynamo 1.2, just stop, stop right now and focus your time and effort on current releases.
  2. #12
    May 31, 2018
    Quebec, Canada
    170
    11:06 AM
    Quote Originally Posted by Bjorn_K View Post
    Why is it irrelevant?
    Thanks for the excel cue!
    **update** I was using the dynamo from 2021 which is not 1.2.2 , I tought it was the 1.2.2 since I installed it.. but it was not. So I took the moment to remove others from my computer! thanks
    Yeah I am downloading right now, sorry last time I checked on autodesk store it was the last version. I am redownloading it! thanks sir!
  3. #13
    April 8, 2011
    428
    12:06 PM
    Your testing the same script against different templates.
    The error in your script is in the step that it asks the BuiltInCategories for its Name in string format and that the action cannot be done. So it does not matter what Categories they are or what template is active in Revit. The object type of which you ask the name is probably not compatible with the way that Node asks the Name.
    Like I said earlier, I see nothing smart or efficient in collecting all (!) the Categories in Revit, ask them for their name and then comparing them to a very select list of names in an excel sheet.
    Could be a lot less resource intensive by just asking a Categoy.ByName using the first column from the Excel. (Assuming the excel and the Revit install are in the same language)
  4.    #14
    May 31, 2018
    Quebec, Canada
    170
    11:06 AM
    I tought you were saying entire script was wrong and useless. I agree, it is huge for maybe not too much ! I will rework around it, I will keep the frame to guide me and learn trought it!
    Thanks for your advice sir! I will let you know when I'm done
  1. Revit character search. An all inclusive equivalent to Ctrl + F
    Last Post: January 13th, 2017, 04:53 PM
  2. Is there an equivalent function in Revit for the AutoCAD LOFT?
    By cve60069 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 7th, 2016, 02:25 PM
  3. Google Map Image or equivalent in a 3d view
    By Usernumerouno in forum Architecture and General Revit Questions
    Last Post: October 31st, 2015, 03:56 AM
  4. Equivalent command to Layoff
    By dvereber in forum Structure - General Questions
    Last Post: June 11th, 2014, 10:56 AM
  5. Equivalent of 3dMaxs's UVW map in Revit
    By kjubas in forum Architecture and General Revit Questions
    Last Post: April 4th, 2014, 03:36 PM
