Results 1 to 10 of 14
Thread: Equivalent node
    May 31, 2018
    Quebec, Canada
    170
    02:21 AM
    Equivalent node
    Hey guys,
    I am having an issue, I am following a course and it requires the Documents.Builtincategories from clockwork. I can,t find the node AT ALL. Is there an alternative?
    The goal is to work with excel and extract datas.
    Revit 2021
    Clockwork: 0.9.x
    Dynamo: 1.2.2
    Thanks for your hep!
    November 4, 2012
    Budapest, Hungary
    159
    03:21 AM
    This node should be inside clockwork 0.9. If you can't find it, just paste the code from github into a python node: https://github.com/andydandy74/Clock...nCategories.py
    Or you can download the dyf file, and copy it manually to your node folder: https://github.com/andydandy74/Clock...Categories.dyf
    These are links to the 0.9.x folder, so this should work for your installation.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    429
    03:21 AM
    Dynamo 1.2.2 and Revit 2021?
    That is an error, or you might want to talk to the course leader about wtf is happening here.
    November 4, 2012
    Budapest, Hungary
    159
    03:21 AM
    It's not that hard to change dynamo version: https://www.sixtysecondrevit.com/202...on-revit-2020/ It shouldn't affect nodes in packages if the correct package version is installed.
    I guess they have a lot of 1.x scripts, and they don't want to update to 2.x.
    April 8, 2011
    429
    03:21 AM
    LOL,
    Except those nodes rely on the API of the Revit versions that actually use 1.x Dynamo versions.
    That's not a reason, that's an excuse to not do what needs to be done.
    May 31, 2018
    Quebec, Canada
    170
    02:21 AM
    I talked to the class guy, it is a 15,99 class on UDEMY.. he doesnt answer quick at all.. been 3 weeks ahah
    at this price id do same, cant blame him! will try to use python ! thanks guys you are insane!
    May 31, 2018
    Quebec, Canada
    170
    02:21 AM
ID:	39614Click image for larger version.
    I found the node but now it is m category.Name that doesnt get the information , Do you guys know the error message?
    April 8, 2011
    429
    03:21 AM
    Category.Name needs a Category as input, not Revit.DB element.
    Looks like you need a list of Category Names there? But why would you need a list of ALL the Category Names there? Might be easiest to just make a List with the Names that are relevant to your needs.
    May 31, 2018
    Quebec, Canada
    170
    02:21 AM
    Normally, the categories are defined on an excel file. So by having all categories listed, you allow your excel document to come pick which one you need ! But maybe it is because structural template and my excel file is not structural. So I can't associate both together. Either I put both structural or not would that make sense.. will try this afternoon!
    May 31, 2018
    Quebec, Canada
    170
    02:21 AM
    Normally the category name should come from that excel file, then schedule should take the information there and all..
    I tried with architectural template and it doesnt change anything
    If I change the documents. node, and add specific categories it doesnt work somewhere else!
  1. Revit character search. An all inclusive equivalent to Ctrl + F
    Last Post: January 13th, 2017, 04:53 PM
  2. Is there an equivalent function in Revit for the AutoCAD LOFT?
    By cve60069 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 7th, 2016, 02:25 PM
  3. Google Map Image or equivalent in a 3d view
    By Usernumerouno in forum Architecture and General Revit Questions
    Last Post: October 31st, 2015, 03:56 AM
  4. Equivalent command to Layoff
    By dvereber in forum Structure - General Questions
    Last Post: June 11th, 2014, 10:56 AM
  5. Equivalent of 3dMaxs's UVW map in Revit
    By kjubas in forum Architecture and General Revit Questions
    Last Post: April 4th, 2014, 03:36 PM
