Thread: Navisworks - properties missing
    Forum Addict
    1,007
    09:32 AM
    I am not sure if anyone else is trialing the BIM360 + Navis coordination tools but I recently encountered an issue I am as yet unable to solve.
    When I load in my models, I do not have all the parameters available that I have in my normal NWC file type.
    For example, I want to see parameters classed under the category "object" for my research parameters, but for some reason all I see is
    Element
    Geometries
    Properties
    Timeliner
    Transformation
    I have checked that its not because of the search definitions, I have them on the same as I do normally and I can see them in the other native file type but not when I open the coordination views from BIM360.
    I have checked my "options" to make sure it converts the properties of elements, but still no joy.
    I am wondering if this is a limitation of the BIM 360 coordination, or if I am missing an option or something else to allow me to see the properties.
    Anyone able to help?
    Forum Addict
    1,007
    09:32 AM
    Spent a bit of time looking into this problem yesterday.
    Actually the same properties are available, but they are listed completely differently.
    I had to go to the "Properties" choice out of that list in the above comments, (normally the property I need is categorized under "object")
    It was then under this list but buried under the associated sorting paramater from revit (ie. dimension, other, comments, data, structure...etc etc)
    So it was labelled as "Other:<parameter name>" and so was buried somewhere that I was not looking for it.
  1. Missing Dims from Properties of selected element. Help!
    By robuovo in forum Structure - General Questions
    Last Post: August 22nd, 2017, 10:18 PM
  2. NAVISWORKS Properties
    By mpwolfe in forum MEP - General
    Last Post: January 11th, 2017, 07:44 PM
    Last Post: September 12th, 2014, 12:45 AM
  4. missing project browser & properties icon
    By frelli in forum Architecture and General Revit Questions
    Last Post: June 19th, 2014, 05:06 PM
  5. Properties Dialog Thumbnail Preview missing
    By Ben-May in forum Architecture and General Revit Questions
    Last Post: February 23rd, 2011, 12:55 AM
