Thread: Phantom sheet that I can't get rid of
    October 22, 2020
    Virginia Beach, Virginia, USA
    05:15 AM
    Question Phantom sheet that I can't get rid of
    Revit 2020.
    Using a template given to us mandated by the project owner, I have come across a phantom sheet. By that, I mean that it shows up in the Sheet List schedule, but does not show up in the Sheet Index schedule or the actual list of sheets in the project browser (see screenshots).
    I can rename the sheet in the Sheet List schedule (which you can see, I have done) and the fields for the Index & List are the same & checkbox for itemize all instances are checked in both.
    If the sheet exists, why doesn't it show in the project browser? How can I delete this phantom sheet? The client has a number of QC checking softwares (etc.) that will surely turn this up as an error when we go to submit.
    Can anyone out there help with this? We are completely baffled by this.
    Please & thank you in advance!
ID:	39599Click image for larger version.
ID:	39600Click image for larger version.
    Senior Member Alex Page's Avatar
    Wellington, New Zealand
    756
    10:15 PM
    You can add sheets to that list as placeholders without actually them being used (so they wont show up in your project browser).
    They show up when you go to create a new sheet.
    You can either delete the row from the schedule (if you certainly dont need it), or filter the schedule so they dont show.
    Refer images - easy to explain!
Name:	filter placeholders.png
ID:	39613   Click image for larger version.
ID:	39612   Click image for larger version.
    October 22, 2020
    05:15 AM
    It was literally that easy. Been using Revit since Revit Structure 2 and never knew about placeholder sheets.
    Thanks very much for the help!
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,592
    02:15 AM
    Placeholder sheets are very handy! You can use it to set up sheet names/numbers that may be used, but we primarily use them to set up sheets we receive from consultants that don't have a model so they appear in the sheet index in the same style as all the model sheets.
  1. Phantom Reference Planes
    By Jozi in forum Architecture - Family Creation
    Last Post: April 15th, 2018, 07:17 PM
  2. RTC: DJI Phantom 4 Locked on Target
    By RTC in forum Blog Feeds
    Last Post: March 15th, 2016, 03:15 AM
  3. Phantom rooms in groups
    By DavidLarson in forum Architecture and General Revit Questions
    Last Post: February 4th, 2016, 10:19 PM
  4. Phantom Type Creation
    By snowyweston in forum Architecture and General Revit Questions
    Last Post: November 17th, 2015, 12:12 PM
  5. Do U Revit: Phantom Keynotes 2.0
    By Do U Revit in forum Blog Feeds
    Last Post: July 21st, 2014, 04:45 PM
