Thread: Revit 2021 and Autodesk Robot 2020
    Lurker
    October 27, 2020
    11:01 AM
    I'm having serious issue with integrating Autodesk Robot 2020 with Autodesk Revit 2021. I downloaded extensions but none has worked so far.
    Forum Addict
    December 16, 2010
    1,046
    08:01 PM
    I am not familiar with Robot compatability, its been a long time since I used Robot with Revit, but as a general rule the plugin needs to be updated to the Revit UI so check your plugin compatability with that version of Revit. In some cases even the hot fix (so like 2021.1) might not work with the most recent plugins until they update them - this needs to come from Robot and not Revit. You should contact Robot and ask them if there are known compatability issues, and which version you need to have work with your current revit version.
    Senior Member HansLammerts's Avatar
    April 22, 2011
    509
    11:01 AM
    -1 Not allowed! Not allowed!
    Something else then Autodusk.
    Heard some good things about Sofistic.
    The 'DWG version', that is ..
    https://www.sofistik.com/products/fi...m-professional
    Last edited by HansLammerts; October 29th, 2020 at 02:58 PM. Reason: oops wrong link
    Autodesk Scott D Davis's Avatar
    March 5, 2011
    Southern California
    737
    02:01 AM
    Quote Originally Posted by rasheed View Post
    you should be running Robot 2021 with Revit 2021. Upgrade your version of Robot in the Autodesk Desktop App
    January 19, 2021
    10:01 AM
    It turns out, even if the versions of one year they may not fit. I need to check with the developer, right?
    Last Post: June 25th, 2020, 12:45 PM
  2. Replies: 0
    Last Post: May 28th, 2020, 03:15 PM
    Last Post: September 8th, 2014, 03:45 PM
  4. Replies: 0
    Last Post: January 4th, 2014, 06:15 PM
    Last Post: May 18th, 2012, 02:15 PM
