Thread: Matching Fabrication Service and Specification
    New Member MADigital's Avatar
    September 12, 2015
    4
    04:14 PM
    My apologies if this has been asked previously, I couldn't find a record of it . . .
    I have a duct drawing where the ductwork has been converted to Fabrication parts from the engineer's items. When the conversion was done, (changing to fabrication parts in lieu of Design Parts) the correct Services and Specifications were not always selected. As a result I now have a floor of mixed systems with different, (incorrect) services and specifications. I have been trying to match properties somewhat similar to how one would do in Fabrication CAD MEP to no avail. Is there a way to match properties or convert my systems to the correct Services and Specifications without having to re-draw all my ductwork? Thank you in advance.
    ~Michael
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    420
    02:14 PM
    2 Not allowed! Not allowed!
    It's nice when your services use the same service template which makes swapping supply/return or san/vent super handy just by changing the service in the Revit properties palette.
    There is a change service option which is designed to do what you want, but I believe it relies solely on button code mapping. Your mileage may vary on that successful operation.
Name:	change service.jpg
    September 12, 2015
    4
    04:14 PM
    Well thank you 'TFuller'! I do appreciate it sir.
  1. Fabrication Parts and Service
    Last Post: November 26th, 2019, 09:36 AM
  2. Replies: 2
    Last Post: August 24th, 2018, 07:09 PM
  3. specification
    By Monikka in forum MEP - General
    Last Post: December 10th, 2014, 11:56 AM
  4. Sheet Specification
    By Versiamo01 in forum Architecture and General Revit Questions
    Last Post: November 3rd, 2014, 06:49 PM
    Last Post: December 12th, 2012, 06:15 AM
