Results 1 to 10 of 12
Thread: Halftone not showing in print file
    July 26, 2018
    35
    01:15 PM
    Hi. Hope you're all doing great.
    I have run into a problem that my print files are not showing the halftone elements in the file. I have checked all the properties but I can't seen to figure out the problem. If anyone can help me with this I'll be grateful. I'm attaching the screen shots.
    Thank you for help in advance.
ID:	39628   Click image for larger version.
ID:	39629   Click image for larger version.
ID:	39630   Click image for larger version.
    11,381
    02:15 AM
    If you go to Manage Ribbon > Additional Settings > Halftone / Underlay, can you screenshot the settings there?
    EDIT: Also, have you tried it with the FoxIt Printer Properties on Color, instead of Black and White?
    July 26, 2018
    35
    01:15 PM
    Yes i have tried the FoxIt printer properties on color and the result is same and in grey-scale the gird is black while the whole building turns half tone. I'll attach the result of grey scale too.
ID:	39634Click image for larger version.
    11,381
    02:15 AM
    Quote Originally Posted by alycealvi View Post
    Hate to say it, but have you tried another PDF printer?
    July 26, 2018
    35
    01:15 PM
    Can you suggest any? I only know of Foxit that print sheets
    11,381
    02:15 AM
    Ive been using the Bluebeam PDF Plotter for years. As long as you set the Bluebeam administrator to Not open PDF's after creation, and not prompt for a file name, its epic fast, at doing tons of sheets.
    Ive also used the Adobe one.
    WAY back in the day i bounced between a few free ones... but i havent had to in a decade.
    Wellington, New Zealand
    756
    09:15 PM
    2 Not allowed! Not allowed!
    Weve gone compeltely off Foxit and recommend to our clients not to use it: we are finding too many inconsistancies with it.
    Personally: Id go with the free dirroots "Prosheet" addin that allows a lot more control over sets of sheets, and it comes with PDF24 as its print engine wheichj we have no problem with.
    Member scourdx's Avatar
    July 4, 2013
    88
    12:15 AM
    Try ForgePDF or CutePDF
  9.    #9
    Member cerb0z's Avatar
    July 5, 2011
    Belarus, Minsk
    252
    11:15 AM
    Quote Originally Posted by Alex Page View Post
    Second DiRoots Prosheets, it's awesome.
  10.    #10
    July 26, 2018
    35
    01:15 PM
    I'll try the one you suggest and report back on what happens!! Thanks for help
  1. Showing Phase II halftone
    Last Post: June 6th, 2017, 12:49 AM
  2. Print order placing halftone over black lines
    By DavidLarson in forum Architecture and General Revit Questions
    Last Post: March 17th, 2016, 07:46 AM
  3. View title is showing up as halftone
    By nworbjt in forum Architecture and General Revit Questions
    Last Post: December 22nd, 2015, 06:50 PM
  4. Perspective showing portion of wall(s) halftone
    By cgallatin in forum Architecture and General Revit Questions
    Last Post: February 5th, 2014, 07:39 PM
  5. Floor Fill showing on Print
    Last Post: October 9th, 2013, 02:41 PM
