Thread: How to edit the default length of plan/ceiling/roof/elevation/etc note leader line?
    October 30, 2020
    03:17 PM
    It's a small annoyance, but does anyone know how to change the default length of how long a plan note leader line is when adding a new leader line?
    Example #1: When zoomed in to place notes and detail plans, you add a leader line and it ends up being out of your view (see attachment). So then you have to scroll over, zoom out, grab the arrow head, zoom back over, and place the arrow head where you want it.
    Example #2: If you're in an enlarged RR plan, you add a note and add a leader line. Since the leader line often goes outside the annotation crop region, the note disappears. So then you have to turn on the crop region (if it's hidden which I usually like to hide them), drag the annotation crop region out to reveal the plan note, then repeat the steps in the previous example.
    Repeating these steps over and over wastes a bit of time that does add up.
    If there is a way to reduce the leader line length, that would save so much time.
    Please help!
    Thank you
Name:	Screenshot 2020-10-30 102508.jpg
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    416
    09:17 AM
    I have been using it for a number of years & know your annoyance first hand
    No solution that I know about to fix it - it is what it is
    Whangarei, New Zealand
    188
    09:17 AM
    In the options bar, select "free......" (not in front of Revit at the moment) in the leader attachment dropdown.
    Sent from my Mi A3 using Tapatalk
    October 30, 2020
    03:17 PM
    Quote Originally Posted by Chris Needham View Post
    I believe you're thinking of the wall/roof/floor "Tag by Category" tag which can either be "Attached End" or "Free End" in addition to being able to adjust and specify the overall length of the leader line (see attached).
    I'm asking about the plan/ceiling/roof notes that you find in Annotate -> Symbol
    Thanks
Name:	Screenshot 2020-11-02 082520.jpg
    February 24, 2011
    Auckland
    416
    09:17 AM
    To clarify
    Symbols don't at the moment have a default length that is adjustable & they always are added to the left side of the Symbol
    Tags on the other hand do have a default length that is adjustable
  1. Can't edit text within a Note Block
    By HenryD in forum Architecture and General Revit Questions
    Last Post: March 21st, 2019, 08:38 PM
  2. Edit Leader Line
    By CRapai in forum Architecture and General Revit Questions
    Last Post: March 13th, 2019, 11:44 PM
  3. default length of a leader on a generic annotation symbol
    By msanchez in forum Architecture and General Revit Questions
    Last Post: October 4th, 2018, 07:08 PM
  4. Generic Annotation Leader Line Length
    Last Post: May 15th, 2014, 08:20 PM
  5. ceiling symbols visible in roof plan view
    By lost again again in forum Architecture - Family Creation
    Last Post: February 19th, 2014, 07:25 PM
