Results 1 to 3 of 3
Thread: Title Block with Editable Identity Data
    July 17, 2015
    11:26 PM
    Morning All,
    I am hoping someone can help me with a Revit query.
    I have created a title block for use in a project at work. However, I am now stuck on how to add text options that will appear within the Properties dialogue box of the sheet that can be edited via the identity data menu.
    I am aware it something to do with parameters/shared parameters, but my knowledge base is not deep enough to enable me to make this work properly.
    Fingers crossed that someone out there will be able to nudge me in the right direction.
    Thanks in advance.
    Forum Addict
    December 16, 2010
    1,029
    09:26 AM
    When you are in the titleblock family you can add a text (which is "dumb" text and can not change)
    or you can add a "label"
    The label will report a parameter.
    For title blocks there are sufficient parameters to report to fill out your title block without having to add shared parameters, although shared parameters are an option also but are a bit more complicated to manage.
    Junior Member Kate's Avatar
    September 4, 2014
    Ann Arbor, MI
    49
    06:26 PM
    Hi Phoenixkeeper,
    I have also found the need to add some additional parameters for sheets beyond what is provided in Revit.
    Below is a description of how I have gone about this.
    I start by adding a shared parameter while in the titleblock family. An easy way to do this is create the label you want to contain the text option, then edit the label.
Name:	01_Edit Label.PNG
    Then hit the "new parameter" button.
Name:	02_New Parameter.PNG
    Then click through to select the shared parameter type.
    I already have a shared parameter group, so here is what it looks like for me. You'll want to hit the edit button in order to add new parameter groups or shared parameters.
Name:	04_Shared Parameters.PNG
    Then you'll be able to add a new parameter group (arrow with #1) and new parameters (arrow with #2). As you can see, I have a parameter group for sheet properties. There are a variety of ways to organize your shared parameter files, this is just the approach I took.
Name:	05_Edit shared parameters.PNG
    Adding a parameter group (#1) is just typing something into the name box.
Name:	06_parameter group name.PNG
    Adding a new parameter (#2) can require a little more care. For your case you would want to change the type to "Text" or "Multiline Text". Changing the Discipline changes what types of parameters are available to select, but I don't think you'll need anything besides "Common" for your titleblock.
Name:	07_New Parameter.PNG
    After adding the parameter(s) you want, you can finally close out back to the Shared Parameters window and select the parameter you want to use in your label. In the image below I've selected Unit Number.
Name:	08_Parameter Selection.PNG
    Hit OK, and then OK again back on the Parameter Properties tab.
Name:	09_OK on param properties.PNG
    Now your new parameter should appear as an option to add to your label. Highlight it and then move it over into your label.
Name:	10_Add to label.PNG
    Now you can go ahead and load the titleblock into your project.
    At this point, the parameter still won't appear on the properties palette for your sheet. In order to show it, we need to add the shared parameter to the project.
    To do this, go to the Manage -> Project Parameters menu while in the project file.
Name:	11_Project Parameters project file.PNG
    Click "Add"
    Then select the radio button next to Shared Parameter (#1), and hit the button to Select (#2)
Name:	13_Shared Param.PNG
    Then select the parameter you want to add and hit OK.
Name:	14_Select Parameter.PNG
    Now you'll need to change the Parameter Data radio button to "Instance" (#1), and then select "Sheets" from the Categories menu on the right (#2). I don't believe you can add type parameters for sheets.
    You can also change where the parameter will appear in the properties palette by changing the selection of the "Group parameter under" drop down on the bottom left. Based on your post, it sounds like you might want to make this Identity Data.
    Hit OK here, and then again on the project parameters window. Your selected parameter should now be visible here.
Name:	16_Project params.PNG
    Now your parameter should appear on the properties palette of your sheet! Make sure you don't have the titleblock selected when you are trying to edit the sheet parameters.
Name:	17_Sheet parameter appears.PNG
    Once you edit the text on the properties palette, the text will appear in the label on your sheet!
    As Karalon10 alluded to there are definitely some complexities / nuance to managing the Shared Parameters file, and depending on the size of your office that is something that can require a bit more overall management.
    But for me, where I'm often the only person doing the drafting, I've found using the shared parameters file to have more benefits than drawbacks.
ID:	39868   Click image for larger version.
Name:	11_Shared Parameters project file.PNG
    Last Post: February 13th, 2020, 11:45 AM
  2. Title block parameters not directly editable
    By PatrickGSR94 in forum Architecture and General Revit Questions
    Last Post: January 20th, 2020, 04:46 PM
  3. Tagging Identity Data
    By domsib in forum Architecture and General Revit Questions
    Last Post: July 16th, 2014, 11:18 PM
  4. parameters for identity data
    By jgu in forum Architecture and General Revit Questions
    Last Post: December 21st, 2012, 03:53 PM
  5. Replace tilet block with title block
    By Charles Karl in forum Architecture and General Revit Questions
    Last Post: May 4th, 2012, 10:48 PM
