Results 1 to 3 of 3
Thread: Run the same Dynamo script for put various family type instances??
    September 21, 2020
    12
    11:08 AM
    I'm doing an automation for put hangers in pipes and ducts. I already done that, but when I run the Dynamo script multiples times with different pipes, it erase the last hangers and put news in the selected pipe.
    I don't know how to tell Dynamo that the run it's done and need to create new instance, I guess with a python script is possible but I don't know if with the build in nodes I can do it.
    I'll appreciate any feedback, thanks.
    1,796
    05:08 PM
    The easiest way is to close the script and open it again to run it a second time, or use Dynamo Player.
    What dynamo does is keep selections over different runs unless something changes in the graph, this is why some nodes have a Run Me (or something similar) input for a boolean node.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    435
    05:08 PM
    In Rhythm there is also the Bake node that removes the element binding from the graph.
  1. Replies: 2
    Last Post: November 12th, 2019, 08:43 PM
  2. Help with a Dynamo Script - copying groups across views
    By guitarchitect in forum Dynamo BIM
    Last Post: June 12th, 2019, 03:40 PM
  3. python/code/script/dynamo??¿¿ how does it work
    By philsogood in forum Architecture and General Revit Questions
    Last Post: January 7th, 2019, 10:00 PM
  4. Replies: 2
    Last Post: April 12th, 2016, 09:06 PM
    Last Post: July 1st, 2013, 01:15 PM
