Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Ugliest Elevation Markers ever?
  1.    #11
    Forum Addict willsud's Avatar
    Ambleside, Lake District, UK
    1,112
    06:23 PM
    UK templates also use the round version.
    I just wish we could have the round arrowheads by default at both ends - or is that some sort of convention to have an arrow at only one end?
  2.    #12
    4,489
    06:23 PM
    ? We can (head and tail are set in the section type property dialog - yes, by default, (OOTB) they're assigned head & tail heads respectively, but you can set your "head" (circular, square, whatever) to head & tail.
Name:	2020-11-15_002431_Type Properties.png
  3.    #13
    1,112
    06:23 PM
    Thanks Snowy - I was sort of hoping someone would say it can be done - just another one of those things you absent-mindedly put up with for years and never get round to properly investigating
    cheers,
  4.    #14
    4,489
    06:23 PM
    Thanks Snowy
    my pleasure - screenshot fails to show what I was actually trying to say, but you get the idea!
  5.    #15
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    416
    07:23 AM
    Quote Originally Posted by Robert Roffe View Post
    One thing about that type of exterior elevation markers is that the middle line will rotate from horizontal when creating a view parallel to a wall that isn't orthogonal to the view, BUT if you add an extra pointer at an angle perpendicular to the wall, the line will stay oriented correctly. It makes for a messy looking family, but nicer looking drawings. Obviously you'd want to do this per project.
    A good workaround to this issue is to use a piece of text, and an "underscore" character, to generate this "Line" inside the circle
    It will then rotate along with the labels correctly
  6.    #16
    September 19, 2017
    Seattle, WA
    102
    10:23 AM
    Quote Originally Posted by d.stairmand View Post
    I mean it works, but not having lineweight control would annoy me. That's before considering any possible font compatibility issues. Adding an extra pointer requires very little effort and works exactly how Revit wants it to work. Not to say it isn't a bit of a silly system in the first place, but why work around that only appears to be broken?
  7.    #17
    11,396
    12:23 PM
    Using the underscore has nothing to do with the pointers. Mine have been underscores for years.
    BUT... For elevations, it doesnt automatically solve the rotation issue like it does for Sections. At least, not here it doesnt.
  8.    #18
    September 19, 2017
    Seattle, WA
    102
    10:23 AM
    My first post had pictures that made my point clearer. Adding extra pointers as needed keeps the elevation marker from rotating because Revit has one to use that's perpendicular to the wall. You don't need an underscore as Dwane is suggesting to get a horizontal line. I've never used that method so I don't know how well it works or not.
  9.    #19
    11,396
    12:23 PM
    Ahh, i see what youre saying now.
    So, we use the Underscore method for other reasons, as well: They allow the circles to be completely masked out.
    Its less helpful with this exact problem, correct. Your method looks fantastic, graphically. Not sure id want to deal with angle parameters at every Elevation Head, though. But it looks great!
  10.    #20
    September 19, 2017
    Seattle, WA
    102
    10:23 AM
    Oh I don't control them parametrically, but typically I don't see anything from architecture until the massing phase is over. Easy enough to go in after the fact and add all the pointers I need for the angles they've stuck me with (and then bemoan the number of custom elbows I'll have to call out for fabrication...).
    I had a feeling that the masking was the reason you were using the underscore. It bugs me to no end that the default section line will always be behind a masking region, even if you cut/paste to same place. Sometimes the only thing consistent with Revit is that it's inconsistent. Though once I figured out how text rotates in a section, it opened up the world to all variety of other section head styles.
  1. Filter Elevation Markers
    Last Post: August 17th, 2020, 04:51 AM
  2. Elevation Markers
    By JT44 in forum Architecture and General Revit Questions
    Last Post: October 24th, 2018, 08:27 PM
  3. Elevation markers missing
    By dukof in forum Architecture and General Revit Questions
    Last Post: October 9th, 2017, 02:28 PM
  4. Hidden Elevation Markers
    Last Post: June 27th, 2013, 05:27 AM
  5. Cant see elevation markers or grids - all turned on.
    Last Post: June 23rd, 2013, 03:30 AM
