Results 1 to 10 of 15
Thread: Adding/removing siding to a wall
    Junior Member Bonsaibob's Avatar
    November 10, 2020
    New Hampshire, USA
    11
    07:27 PM
    Hello,
    I work at a design build firm, and we export our Revit files to a program called Cadwork. The firm has never added siding to our Revit projects because when we transfer to Cadwork we don't care about siding. So, it makes the Revit model inaccurate. Exterior window trim sticks out way too far (1" instead of 1/4") because of the lack of siding.
    My question: when exporting a Revit model to Cadwork, is there a way to remove the siding upon export? In ArchiCAD (my previous program) this was very easily done. You identified parts of a wall as "structure", "finish" or "other" and can set each one to not show/export.
    Ideally, we have siding in Revit and remove it when transferring to Cadwork.
    1,747
    01:27 AM
    I'd say make the sidings a separate wall and turn them off with a filter in your export view.
    Do you export to IFC for Cadworks (never heard about that software)?
    In that case make sure that you have the option 'export only visible objects' (or something like that, selected
    November 10, 2020
    New Hampshire, USA
    11
    07:27 PM
    Making a separate wall sounds like a bad workaround
    I'll check to see how we export the files. Cadwork is a CAD/CAM software that speaks directly to our CNC machines. The option to only export visible objects sounds promising.
    11,397
    06:27 PM
    Quote Originally Posted by Bonsaibob View Post
    Im sure it sounds that way, coming from ArchiCAD. But- for a whole host of reasons- youll learn that in Revit, its generally favored to segregate making "backup walls" and "finishes" out of completely separate elements. Yes, there are "Layer Structure assignments" in Revit too, but currently they arent defeatable, part instead of parcel.
    Unless you use the Part command to part all of your walls, at which point you can 100% hide (or Filter) any Parts that you want, including those that dont have specific Materials in them. We do this when we export to Navisworks for Construction Coordination, so the Plumbing Subcontractors get just the Stud Layers and Air spaces of the walls, so they know what targets to hit.
    November 10, 2020
    New Hampshire, USA
    11
    07:27 PM
    This is exactly what I think I'm looking for. We did something similar in ArchiCAD when exporting drawings to structural engineers. We just showed the structure.
    I'll look into the Part command.
    11,397
    06:27 PM
    If you look in to Parts, i would suggest looking in to Dynamo, as well. Because Parting doesnt create multiple WALLS, it creates PARTS from Walls. That means objects visibility status will be different depending on your view template, and whether or not it is parted (showing Parts) or not (showing Walls).
    So we use a Dyn that parts all walls, for that specific purpose.
    3,425
    06:27 PM
    Bonsai, this isn't going to help you now, but Autodesk just updated their Revit Roadmp
    https://trello.com/b/ldRXK9Gw/revit-public-roadmap
    Under For Architecture there is a topic labeled
    Show Wall Core in Plan views
    which sounds like exactly what you're looking for.
    So: not yet, but probably in an upcoming version.
    New Revit versions usually are released in March
  8.    #8
    November 10, 2020
    New Hampshire, USA
    11
    07:27 PM
    Wink
    Thanks. I'll add this to the ever growing list of things that ArchiCAD does really well and Revit doesn't
  9.    #9
    2,875
    05:27 PM
    Maybe find a job that uses ArchiCAD then?
  10.    #10
    November 10, 2020
    New Hampshire, USA
    11
    07:27 PM
    Greg,
    Since my current employer uses Revit, trying to find a way to accomplish this simple task within Revit would be preferable, don't you think?
  1. Posts not showing properly after removing wall
    By glkirk in forum Architecture and General Revit Questions
    Last Post: February 6th, 2019, 06:03 PM
  2. Adding wall paneling
    By Hocine in forum Architecture and General Revit Questions
    Last Post: April 24th, 2018, 03:16 PM
  3. Removing Sill or Sweep off Brick Wall
    By sierrapenas in forum Architecture and General Revit Questions
    Last Post: February 16th, 2016, 08:17 PM
  4. Problem with adding custom curtain wall panels to curved curtain wall.
    Last Post: November 20th, 2013, 07:16 PM
  5. Removing wall foundation
    Last Post: October 2nd, 2013, 08:44 AM
