Thread: Revit- wall with changeable thickness
    February 10, 2020
    6
    01:39 AM
    Hello,
    I have a question about the easiest way how to make model of this type of wall with changeable thickness. The aim is to make model of building using only this type of walls (the same or different but with changeable thickness because of columns and beams), so I need the fastest way. Thank you. Click image for larger version.
Name:	Bez tytułu.jpg
    November 4, 2012
    Budapest, Hungary
    159
    01:39 AM
    - If you want to reuse this with different sizes, your best bet is a custom loadable family. By default you cannot select wall category for a loadable family, so you will have to use some other category, or you can find a wall family template on the forum. I don't know the source of that template, but somehow someone created that. If you can't find it I can upload it.
    - If the different panels are really different from each other, than maybe it's not viable to create a family. In that case you have some options:
    - Regular walls with wall sweeps and reveals.
    - You can create some part of it as a compound wall with modify section. Using these commands are not really straightforward: https://knowledge.autodesk.com/suppo...67786-htm.html
    - Absolute last option is an in-place family.
    February 10, 2020
    6
    01:39 AM
    Quote Originally Posted by infeeeee View Post
    Thank you . I can't find it, if not a problem please upload it I'd be greatful. Thank you once again!
    November 4, 2012
    Budapest, Hungary
    159
    01:39 AM
    You can download from here: https://mega.nz/file/WsZgnbhB#qyCqgU...Ygz670_so46Awc
    There was a floor version as well, I couldn't find where I downloaded from, but it was from this forum.
    February 10, 2020
    6
    01:39 AM
    Thank you.
    2,842
    10:39 AM
    Wall / floor family templates were likely created by the old 'export from a group' trick. Probably not the best idea to build a project around these as it may cause issues later, and you won't get all the built in capabilities of system families.
    November 4, 2012
    Budapest, Hungary
    159
    01:39 AM
    Autodesk is aware of this category problem, and it's on the roadmap: https://trello.com/c/hXEpSfcw/103-lo...ystem-families
    Here is an idea where you can vote for this feature: https://forums.autodesk.com/t5/revit.../idi-p/8698001
    So we have to wait like 5-10 years, and mybe this will be implemented in Revit!
  1. Revit Families Obscuring Wall thickness.
    Last Post: August 13th, 2020, 01:50 PM
  2. Wall connection ith or without different thickness
    By ARKlm in forum Architecture and General Revit Questions
    Last Post: August 26th, 2019, 08:52 PM
  3. Revit Families Obscuring Wall thickness.
    Last Post: June 18th, 2018, 08:54 PM
  4. Historical wall with different thickness...
    By argonz in forum Architecture and General Revit Questions
    Last Post: December 13th, 2012, 12:46 PM
  5. Change Wall Thickness???
    By corncake21567 in forum Structure - General Questions
    Last Post: June 30th, 2012, 09:59 PM
