Results 1 to 10 of 10
Thread: How dimensions and constraints work
    September 21, 2016
    Boston
    326
    01:53 PM
    I have been using Revit since 2015, and I still don't understand the method behind the dimension tool and how it determines constraints while trying to make something equal between two points. Sometimes it works, sometimes it doesn't; I just don't understand the parameters and what the constraints are. I am intending to place a model item at the center of two points and use the dimension tool to achieve this. In the example (attached image) I am trying to center the model text on the panel. To do this, I placed a dimension string on the end of each of the mullions and when I click the "eq", I get this error. I have also tried creating detail lines, and pinning them, and I still get the same error.
    I am hoping someone can explain to me how this tool works. Why does it seem to work flawlessly sometimes, and other times, like in this instance, it doesn't. it seems arbitrary so of course, I am missing something here.
Name:	Dimensional Constraints issue.PNG
    Member Exar Kun's Avatar
    August 2, 2011
    235
    04:53 AM
    Maybe it's just the model text being funky? Constraints never work well with model text in my experience. I tend to create a component family and place model text in there if I need it to be controlled with constraints - whether that be in a project or nested into another family.
    11,396
    11:53 AM
    It works fine with model text,if the model text is set to center justify. I did it on Friday. Works fine.
    3,425
    11:53 AM
    More often than not, when you get "Constraints are not satisfied", there's something else controlling one of the elements involved.
    Something dimensioned and locked to one (or both) of those walls perhaps?
    Click the Expand button on the error dialog and it will tell you which elements are having problems.
    You can then select one of the elements (in the dialog) and it will highlight it on the View.
    If that still doesn't help, post a screen shot of the expanded dialog & maybe we can better explain something
    2,875
    10:53 AM
    Dimension to the gridline instead. IIR, theres something about mullions that has an issue with dimensions.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,591
    09:53 AM
    Dimension to the gridline instead. IIR, there’s something about mullions that has an issue with dimensions.
    ?? The OP wasnt trying to dimension to a curtain wall mullion as far as could see and dimensioning to and from mullions is never an issue if the profiles are built correctly related to the family ref planes.
    2,875
    10:53 AM
    They look like CW mullions to me but maybe not.
    The issue Im recalling with CW mullions isnt about dimensions but about trying to set an equally constraint when the dims arent already equal. Im not able to get into Revit right now to confirm so totally working from memory.
    You dont still have a sub to Revit, do you Dave?
  8.    #8
    Dave Jones's Avatar
    4,591
    09:53 AM
    Hi Greg, what do you mean by "sub to Revit"??
  9.    #9
    2,875
    10:53 AM
    subscription -- you using Revit in your retirement for fun?
  10.    #10
    Dave Jones's Avatar
    4,591
    09:53 AM
    yep, although not as much as before. Still playing with Dynamo for curtain wall BOM stuff mostly
    Last Post: March 23rd, 2016, 01:15 AM
  2. How to work with revit files of external party (with or without cloud work sharing)
    By sahan in forum Architecture and General Revit Questions
    Last Post: February 6th, 2016, 08:12 PM
    Last Post: September 28th, 2015, 02:15 PM
  4. Angular Dimensions acting like linear dimensions (up-down, left-right only)
    By Jobrowns in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 09:50 PM
  5. Replies: 2
    Last Post: November 14th, 2011, 11:32 AM
