Thread: Copy/Monitor Grid Glitch
    Member UKN's Avatar
    February 16, 2011
    Las Vegas, NV
    86
    10:24 AM
    Hello all!
    I'm experiencing some weird behavior from copy/monitoring the grid from a core and shell project to three different TI models in that particular building.
    Graphically, some of the grids are a little off in the TI models, but when I check the core and shell model - all dimensions are correct and in line with the copied and monitored elements in the TI models. So coordination wise we're good, the linked grid is just off graphically.
    Any of you guys have an idea as to what may be causing this behavior? We have had changes to the core and shell grid, but have modified the grids in all three TI models to accept the grid changes in the core and shell model (coordination review). There are no outstanding coordination review items in any of the TI models.
    Thanks and have a happy virtual AU day!
Name:	CM glitch.PNG
    Member UKN's Avatar
    February 16, 2011
    Las Vegas, NV
    86
    10:24 AM
    OK, I finally figured out what the issue was.
    The core and shell team had just linked a structural model in as attached, and the structural grid was a little off from the original arch design grid. Turns out it's just a normal coordination issue.
  1. Copy Monitor Multisegment Grid
    By bartok in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2015, 10:26 PM
  2. Grid Lines - To Copy/Monitor or Not?
    By psubrian in forum MEP - General
    Last Post: December 23rd, 2014, 10:38 PM
  3. Copy/Monitor changing grid numbers?
    Last Post: September 27th, 2012, 12:57 AM
  4. copy/monitor grid display issue
    Last Post: September 24th, 2012, 10:59 PM
  5. Copy Monitor of Arch Grid Causing Issues
    Last Post: December 7th, 2011, 12:21 PM
