Thread: Detach an element without specifying what its being detached from
    September 21, 2016
    Boston
    326
    08:23 PM
    When you detach an item, like a wall from a roof for instance, you always have to specify the exact item you want to detach it from before you can proceed. This can sometimes be problematic in complex projects, because its either attached to multiple objects, or you need to find the right view to do so. It's not always readily apparent. This is driving me crazy. Is there an option to just detach it from all elements, without having to specify which ones?
    11,397
    06:23 PM
    Quote Originally Posted by katewood1989 View Post
    Once you click Detach, there is a button in the Option Bar (below the ribbon) that says Detach All.
    Last Post: September 13th, 2018, 08:45 AM
  2. dwg underlay - how do you switch it off or detach
    By gbh in forum Architecture and General Revit Questions
    Last Post: June 8th, 2017, 06:46 AM
  3. Workflow for semi-detached housing
    By Jock in forum Architecture and General Revit Questions
    Last Post: October 11th, 2013, 05:10 PM
  4. Batch detach from central?
    Last Post: April 5th, 2013, 04:39 AM
  5. Detach from Central
    By Defiant1 in forum Structure - General Questions
    Last Post: June 20th, 2012, 04:35 PM
