Hi everyone! I'm Lendawn. I have this problem on hiding the split face on a template's Visibility graphics because I couldn't determine to where does it belong. so I couldn't find it there. If just could find it, it would be easy for me to uncheck it there. If anyone here can help me on this. Thank you so much !!![]()
The split face lines are "Projection" lines of the object surface being split. So in VG, you can either change the Projection appearance for the category (Model Tab in VG) or use filters to select specific types/families to modify the Projection appearance. You can't hide it if you want the surface itself to be visible, but if you have a white background, you can change the Projection appearance to white. But that may not give the result you want. Depending on the situation, the linework tool is a decent option, but it is line by line in each view.
