Thread: Optimize duct length
    Member wwdreamb's Avatar
    May 19, 2016
    Honolulu, Hawaii
    125
    02:09 PM
    Question Optimize duct length
    Hey all,
    I'm trying to set up a high-pressure system for a job. The length needs to be 48" max.
    When I go into Fabrication CADmep 2019 and open "Edit Main Database". I created a new Specification "+6WG" as shown in the photo 1.
    Then I went to Setup service and created Service "6in WG" and chose "+6WG" for service spec. (Photo 2)
    When I draw the duct, the length keeps coming out at 44.377" not the 48" I set it to. What am I missing?
Name:	Main database.PNG
ID:	39815Click image for larger version.
Name:	Setup Service.PNG
ID:	39816Click image for larger version.
Name:	Duct Length.PNG
    May 19, 2016
    Honolulu, Hawaii
    125
    02:09 PM
    Got if figured out.
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    423
    03:09 PM
    I'm assuming you had to juggle some connector setup, correct?
    TDC vs. Ductmate sort of thing, plus there's a gasket consideration as well if you're into that...
  1. Place short length at beginning of duct run
    By tawilson in forum MEP - General
    Last Post: August 8th, 2020, 07:26 PM
  2. How optimize script for placed families on drafting view?
    By andry in forum Architecture and General Revit Questions
    Last Post: December 11th, 2017, 08:25 AM
  3. duct with veins, array radius , length increase
    By Hype in forum Architecture - Family Creation
    Last Post: November 21st, 2016, 05:37 AM
  4. Duct Size vs Length parameter
    Last Post: November 26th, 2014, 06:58 PM
  5. Parameters: Duct Size vs Length
    Last Post: May 17th, 2012, 07:18 PM
