Thread: Maintain Symbol Orientation
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    497
    01:34 AM
    Reviving this thread from seven years ago:
    https://revitforum.org/showthread.ph...ol-Orientation
    I see the Maintain Symbol Orientation option is still only available for Electrical Fixtures, Lighting Devices and Fire Alarm Devices. When items of other categories, such as a light fitting or a sprinkler, are placed on a sloped or curved ceiling, their nested annotations do not show.
    If I use Lighting Devices for my ceiling lights and Fire Alarm Devices for my sprinkler heads, then my symbols will show. (Or I could just use Electrical Fixtures for them all.)
    In my architectural model is there a reason why I should not do this? As we move to more multi-discipline collaboration, these items in our model are just placeholders that the engineers take over and place in their models.
    Thanking you.
    Wellington, New Zealand
    761
    03:34 AM
    The more collaborating I do, the less workarounds I try and use, since it just confuses everybody, no matter how well you write it up in the BEP!
    Lighting devices dont have light sources in them, so youll need to nest those in (and probably "share" them so that you can amend them in the project).
    Good news is, its on the Revit roadmap:https://trello.com/b/ldRXK9Gw/revit-public-roadmap
    (and if you join the beta team you can see more for yourself)
Name:	annotation orientation.png
    August 31, 2011
    Sydney, Australia
    497
    01:34 AM
    Good point. Thank you.
    How do you get your annotations to appear when face based items are placed on sloped ceilings, curved ceilings and walls? Manually place the annotation over the top? Nest all the symbols into a tag and then tag the items (manually changing to the appropriate symbol)?
    761
    03:34 AM
    Pendant lights are fine, since you can have "Always Vertical" ticked
    "real size" symbols are fine (i.e. 1200x600mm pan fittings) - make the symbols model lines
    We have very cool adaptive components with all the other "shared" lights and their symbols nested into them to mimic the "maintain annotation" (symbols are set on a adaptive point that is always vertical)
    Does a brilliant job BUT a real pain to use for the poor user!
    We'll be re-making all of those light components once this feature happens.
  1. Revit - Creating a 3D PDF - and maintain Phasing
    By AlBeeryJr in forum Architecture and General Revit Questions
    Last Post: December 2nd, 2014, 08:52 PM
  2. Maintain Symbol Orientation
    By bob_oregon in forum Architecture and General Revit Questions
    Last Post: November 18th, 2013, 08:08 PM
  3. Maintain Circular Symbol Orientation
    Last Post: November 18th, 2013, 06:51 PM
  4. Elec fixt symbol / placement ht / feed value to plan symbol label?
    By Fritz in forum Architecture - Family Creation
    Last Post: November 1st, 2013, 04:53 PM
    Last Post: March 6th, 2013, 11:16 PM
