Thread: Bolts & Anchors Fabrication elements
    December 14, 2011
    61
    07:45 PM
    Under the steel menu, fabrication elements there are bolts and anchors that I am using. Why can't I add dimensions to these for example length of the bolt in section?
    December 11, 2010
    Astana
    287
    01:45 AM
    Unfortunately this is the current limitation. Use a bolt tag to show the length.
    Member Kate's Avatar
    September 4, 2014
    Ann Arbor, MI
    50
    02:45 PM
    I have found that if you have a view showing the bolt head or nut, like in a base plate detail, you can dimension to the bolt centerlines if you change the visual style to wireframe.
    Doesn't seem to work in section, but may be some help.
Name:	Base Plate Dimensions.PNG
  1. Model bolts
    By Procadd in forum Structure - General Questions
    Last Post: December 11th, 2017, 02:39 AM
  2. Rotating bolts (generic Model)
    By akaplan in forum Structure - General Questions
    Last Post: February 25th, 2016, 01:03 PM
  3. verctical bolts
    By akaplan in forum MEP - General
    Last Post: February 22nd, 2016, 05:15 PM
  4. How to make anchor bolts group??
    By madism in forum Structure - General Questions
    Last Post: February 1st, 2016, 07:30 AM
  5. Spacing Bolts
    By sachez143 in forum Structure - Family Creation
    Last Post: February 9th, 2012, 07:20 PM
