Thread: backup file
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    276
    10:29 PM
    backup file
    Hello
    Iĺm wandering why people are so afraid of losing their main file on Revit. I read thread dealing with this is you worh with box.com that work sharing can be lethal for files while synchronisingů
    Every rvt file creats a backup file, as ACAD create a bak. Is it so dangerous to use the backfile for the saving a project which has been corrumpted ?
    Thanks for your enlightments and happe new year 😉
    Phil
    1,801
    10:29 PM
    As far as I know a workshared project does not have a backup file (.0001.rvt, etc.), just from the local files and it is a pain in the @$$ to get from a local file back to a central file especially if you have multiple people in there that all lost work. You need to figure out who has the newest local file, open that, clean that up, put back on the server, make into a shared file again and have everybody make a new local file. And then they all have to go and find out what it is they need to redo.
    If you just work by yourself (as I do) and don't use a work shared project that the backup files works well, but all the backup stuff is in case my NAS stops working and I loose everything, which would be bad.
  1. bug from restoring a backup file ?!?
    By kunster in forum Worksharing and Cloud Coordination
    Last Post: February 11th, 2015, 10:55 PM
  2. File Backup
    By dzatto in forum Out There
    Last Post: February 24th, 2014, 06:20 PM
  3. File recovery and backup Best Practices
    By dp stuff in forum Architecture and General Revit Questions
    Last Post: July 9th, 2013, 05:15 AM
  4. Workshared file corrupt, where's my backup???
    By mdradvies in forum Worksharing and Cloud Coordination
    Last Post: June 27th, 2011, 07:49 PM
