Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Has anyone had luck creating a 2021.1 Deployment with custom Revit.ini file?
  1.    #11
    11,469
    03:22 PM
    Wouldnt be in Roaming appdata. Would be in the temp folder. Which could be %TMP% or %TEMP%. For me, those point to Appdata\local\temp. But its possible they dont stick around long after the deployment failed. Ive always been able to open them right after a failed rollout. But they arent on my machine currently, either.
  2.    #12
    July 7, 2017
    Hernando, MS
    648
    03:22 PM
    ugh, I've got one machine that 2021 absolutely will not install on.
    Tried the deployment. Failed.
    Tried installing from my Autodesk account. Failed.
    Tried downloading the entire install package to our server, and installing from there. Failed.
    Tried removing every folder related to Revit 2021 from AppData, from ProgramData, from Program Files, everything. Failed.
    Each time it fails around 42% and then says the Autodesk Installer has stopped working.
    I don't know what to do at this point. Luckily this isn't a normal production machine, but it's the conference room so we still need it installed on there, to use during meetings and such.
  3.    #13
    Member Markus's Avatar
    July 27, 2012
    Seattle, WA, United States of America
    354
    01:22 PM
    Have you checked in the RVT_2021_install log in the %temp% folder. You may consider hacking the Windows Registry for entries tied to Revit 2021.
    Here is my Powershell script e.g.
    Code:
    # === https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
    # === uninstall Revit
    # (new-object -ComObject wscript.shell).Popup(“uninstalling Revit 2021.” ,1800 ,”Cleaning up Revit 1”,0x30 + 0x0)
    Get-Date
    Write-Host "Uninstalling Revit 2021"
    $R2021_1 = "C:\ProgramData\Package Cache\{fb979c52-2110-496a-a7f6-af0ae79702c6}\Revit_2021_1.exe"
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {7346B4A0-2100-0510-0000-705C0D862004} /passive" –Wait     # Revit 2021
    If (test-path $R2021_1){        # Revit 2021.1
        Start-Process –FilePath "C:\ProgramData\Package Cache\{fb979c52-2110-496a-a7f6-af0ae79702c6}\Revit_2021_1.exe" –ArgumentList '/uninstall' –Wait
        # Revit 2021.1.2
    Start-Process –FilePath "msiexec.exe" –ArgumentList '/uninstall {9CA05B9A-2107-0510-A1B4-FFF7A680FE55} /package {7346B4A0-2100-0510-0000-705C0D862004} /qb FILESINUSETEXT=""' –Wait
    Get-Date
    Write-Host "Uninstalling Revit 2021 Autodesk plugins"
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {AA384BE4-2101-0010-0000-97E7D7D021A0} /passive" –Wait     # Autodesk Cloud Models for Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {AA384BE4-2101-0030-0000-97E7D7D021A1} /passive" –Wait     # Autodesk Cloud Models 21.1.20.44 for Revit 2021
        #       don't uninstall Personal Accelerator for Revit
        #       used by multiple versions of Revit for Cloud Models
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {82AF00E4-2101-0010-0000-FCE0F87021A0} /passive" –Wait     # Batch Print for Autodesk Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {4477F08B-2101-0010-0000-9A09D83421A0} /passive" –Wait     # eTransmit for Autodesk Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {5063E738-2101-0010-0000-7B7B9AB021A0} /passive" –Wait     # Worksharing Monitor for Autodesk Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {A4FE9D6B-F564-4AB1-A539-C65D6D337353} /passive" –Wait     # Autodesk Revit Issues Addin (2021) 1.0.0.0
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {C52C0D6B-722A-4B7D-BF0A-4828F5095D96} /passive" –Wait     # Generative Design For Revit
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {80B2AAE7-4B04-4BDE-B545-DA0298C548FD} /passive" –Wait     # Autodesk Revit 2021 Revit MEP Imperial Content
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {18FAFC92-6F7A-4894-ACD1-19EC6C4E639B} /passive" –Wait     # Autodesk Revit 2021 Revit MEP Metric Content
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {69D8FFED-B14E-4998-BBC2-535006E195D6} /passive" –Wait     # Autodesk Material Library Medium Resolution Image Library 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {CD67BD67-5A43-4D49-8E6D-12C6B97A930B} /passive" –Wait     # OpenStudio CLI 0.1.10 For Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {3BD91CC3-CA0A-4B3D-8950-C21BABFAF61F} /passive" –Wait     # OpenStudio CLI 0.1.17 For Revit 2021
    # === uninstall Material Libraries
    Get-Date
    Write-Host "Uninstalling Localized Content"
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {583895D0-2021-0410-0000-9241AD002DA5} /passive" –Wait     # Autodesk Revit Content Core 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-2052-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-CHS 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-1028-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-CHT 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-1029-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-CSY 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-2057-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-ENG 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-1034-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-ESP 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-1036-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-FRA 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-1040-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-ITA 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-1041-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-JPN 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-1042-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-KOR 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-1045-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-PLK 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-1046-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-PTB 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {848BACE1-2021-1049-A981-1A6F0898E5BC} /passive" –Wait     # Autodesk Revit Content Essential-RUS 2021
    Get-Date
    Write-Host "Uninstalling Material Libraries"
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {8C559572-4A10-43C2-9346-6E7C7E012487} /passive" –Wait     # Autodesk Material Library 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {EFC36459-CD89-44F3-BA04-B7C5804199AF} /passive" –Wait     # Autodesk Material Library Base Resolution Image Library 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {AD6312B6-3056-460A-833F-02654FAC5FCE} /passive" –Wait     # Autodesk Material Library Low Resolution Image Library 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {C9FDA270-A0B9-45EE-8748-F37DF1370767} /passive" –Wait     # Autodesk Advanced Material Library Base Resolution Image Library 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {AB7DC10F-1D72-4F90-988F-CDC2D6323A48} /passive" –Wait     # Autodesk Advanced Material Library Low Resolution Image Library 2021
    # === uninstall Revit plugins
    # Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {E28D1959-CEBC-45E3-9E0B-12857161C886} /passive" –Wait     # STL Exporter For Revit 2020
    # Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {C27DD83E-7B5F-47CA-955C-4EEF1D6F0FC7} /passive" –Wait     # BIM Interoperability Tools for Revit 2020
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {D702AF38-3F62-486C-90DF-D4F91A69795B} /passive" –Wait     # Ideate BIMLink for Autodesk Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {39efdebc-989a-4c7d-a914-52c805569e74} /passive" –Wait     # Ideate BIMLink for Autodesk Revit 2021.1.41422
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {970BB312-6240-41FD-8C8A-CA3A5354E662} /passive" –Wait     # Ideate Explorer for Autodesk Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {52D259FA-5172-4503-A45F-6F95CF765CF4} /passive" –Wait     # Ideate Explorer for Autodesk Revit 2021.1.41425
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {06E5CB54-4E60-4D23-A1E2-E36D26717B88} /passive" –Wait     # Ideate Sticky for Autodesk Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {17dd4b1b-ca24-4b7e-ab4f-9c2e5adb0bd1} /passive" –Wait     # Ideate Sticky for Autodesk Revit 2021.1.41440
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {6FCDE546-9E27-4CB6-ADEC-0727D181BFF1} /passive" –Wait     # Ideate StyleManager for Autodesk Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {62fdd3ee-21e5-4969-ad68-2cdf1e4cb5d8} /passive" –Wait     # Ideate StyleManager for Autodesk Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {BA4B391E-D6EE-4695-B68C-6A9BB0E1325F} /passive" –Wait     # IdeateApps for Autodesk Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {A87C59EE-5A58-4A92-8D5D-051FA8C159BA} /passive" –Wait     # IdeateApps for Autodesk Revit 2021
    Start-Process –FilePath "msiexec.exe" –ArgumentList "/X {5C4FD0AB-ED6A-0409-86FE-BE923A4048ED} /passive" –Wait     # Autodesk Navisworks 2021 Exporters - 64 bit - English Language Pack
    # === delete folders on computer
    $Path01 = "C:\Program Files\Autodesk\Revit 2021"
    $Path02 = "C:\ProgramData\Autodesk\Revit Server 2021"
    $Path03 = "C:\ProgramData\Autodesk\RVT 2021"
    $Path04 = "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\Worksharing Monitor for Autodesk Revit 2021.lnk"
    $Path05 = "C:\ProgramData\Autodesk\Revit Steel Connections 2021"
    if (Test-Path $Path01) {Remove-Item -Recurse -Force $Path01}
    if (Test-Path $Path02) {Remove-Item -Recurse -Force $Path02}
    if (Test-Path $Path03) {Remove-Item -Recurse -Force $Path03}
    if (Test-Path $Path04) {Remove-Item -Recurse -Force $Path04}
    if (Test-Path $Path05) {Remove-Item -Recurse -Force $Path05}
    # === delete Windows Registry keys
    $Reg01 = "HKLM:\SOFTWARE\Autodesk\Revit\2021"
    $Reg02 = "HKLM:\SOFTWARE\Autodesk\Revit\Worksharing Monitor for Autodesk Revit 2021"
    $Reg10 = "HKLM:\SOFTWARE\NREL\OpenStudio CLI For Revit 2021"
    $Reg11 = "HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Autodesk Cloud Models for Revit 2021"
    $Reg12 = "HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Autodesk Revit 2021 SP2"
    $Reg13 = "HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Autodesk Revit 2021 SP4"
    $Reg14 = "HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Autodesk Revit 2021 SP6"
    $Reg18 = "HKLM:\SOFTWARE\WOW6432Node\Autodesk\Updates\Revit\2021.1.2"
    $Reg19 = "HKLM:\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{fb979c52-2112-496a-a7f6-af0ae79702c6}"
    $Reg20 = "HKLM:\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Autodesk Advanced Material Library Base Resolution Image Library 2021"
    $Reg21 = "HKLM:\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Autodesk Advanced Material Library Low Resolution Image Library 2021"
    $Reg22 = "HKLM:\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Autodesk Material Library Base Resolution Image Library 2021"
    $Reg23 = "HKLM:\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Autodesk Material Library Low Resolution Image Library 2021"
    $Reg24 = "HKLM:\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Autodesk Material Library Medium Resolution Image Library 2021"
    $Reg25 = "HKLM:\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\FormIt Converter For Revit 2021"
    if (Test-Path $Reg01) {Remove-Item -Recurse -Force $Reg01}
    if (Test-Path $Reg02) {Remove-Item -Recurse -Force $Reg02}
    if (Test-Path $Reg10) {Remove-Item -Recurse -Force $Reg10}
    if (Test-Path $Reg11) {Remove-Item -Recurse -Force $Reg11}
    if (Test-Path $Reg12) {Remove-Item -Recurse -Force $Reg12}
    if (Test-Path $Reg13) {Remove-Item -Recurse -Force $Reg13}
    if (Test-Path $Reg14) {Remove-Item -Recurse -Force $Reg14}
    if (Test-Path $Reg18) {Remove-Item -Recurse -Force $Reg18}
    if (Test-Path $Reg19) {Remove-Item -Recurse -Force $Reg19}
    if (Test-Path $Reg20) {Remove-Item -Recurse -Force $Reg20}
    if (Test-Path $Reg21) {Remove-Item -Recurse -Force $Reg21}
    if (Test-Path $Reg22) {Remove-Item -Recurse -Force $Reg22}
    if (Test-Path $Reg23) {Remove-Item -Recurse -Force $Reg23}
    if (Test-Path $Reg24) {Remove-Item -Recurse -Force $Reg24}
    if (Test-Path $Reg25) {Remove-Item -Recurse -Force $Reg25}
  1. 2021.1 *New* Deployment
    By mdsweeney4 in forum Architecture and General Revit Questions
    Last Post: January 5th, 2021, 07:30 PM
  2. 2021 Deployment Issues
    By nharburger in forum Architecture and General Revit Questions
    Last Post: September 10th, 2020, 08:53 PM
    Last Post: July 23rd, 2020, 01:15 PM
  4. Problem with deployment not reading my custom .ini file
    By ryntau in forum Architecture and General Revit Questions
    Last Post: September 26th, 2016, 03:42 PM
    Last Post: June 29th, 2016, 12:45 AM
