Thread: How long does it take to install Revit 2021 with the 2021.1.2 hotfix?
    Member Markus's Avatar
    July 27, 2012
    Seattle, WA, United States of America
    354
    01:23 AM
    It seems to take 2-3 hours to install on a Window 10 20H2 workstation from an Autodesk package via a network drive. Is that normal?
    Any ideas why it is taking so long?
    I was expecting 45 minutes instead!
    July 7, 2017
    Hernando, MS
    648
    03:23 AM
    what type of hard drive? Our machines with SSD's install Revit significantly faster than regular spinning platter HDD's.
    July 27, 2012
    354
    01:23 AM
    They are spinning platters. I submitted the log file to Autodesk support for comment. It took about four hours.
    July 27, 2012
    354
    01:23 AM
    I am happy to report that Autodesk recommend that I install directly from their site. It took only 30 minutes! Perhaps Windows Defender does not like my Powershell scripts to run the Autodesk packages.
  1. Revit 2021 - Fontaneria mep
    By newtech in forum Foro Español
    Last Post: November 30th, 2020, 04:16 PM
  2. Revit Server 2021
    By Knitro87 in forum Worksharing and Cloud Coordination
    Last Post: November 23rd, 2020, 10:07 PM
  3. 2021.1 update requires original install files
    Last Post: September 10th, 2020, 08:51 PM
  4. Best PC System for Revit 2021 LT Suite
    By revitmonkey1972 in forum Hardware and Infrastructure
    Last Post: August 1st, 2020, 07:13 AM
  5. Revit 2021
    By therrien in forum Architecture and General Revit Questions
    Last Post: July 28th, 2020, 04:38 PM
