Results 1 to 1 of 1
Thread: Why does Sloped Glazing by Extrusion offset down 4 inches?
    July 7, 2017
    Hernando, MS
    648
    02:39 PM
    I'm trying to draw a sloped window using Roof By Extrusion with Sloped Glazing. When I finish the sketch, the centerline of the entire sloped glazing assembly is offset 4 inches downward (parallel) from my original extrusion sketch line.
    Does this have something to do with the grayed out "Thickness" instance parameter on the Sloped Glazing type, which for me is showing 4 inches? Normally this is the thickness of the roof assembly, but on Sloped Glazing I don't see a way to change that.
Name:	Sloped Glazing.JPG
  1. Curtain Wall & Sloped Glazing
    By eng_xp in forum Architecture and General Revit Questions
    Last Post: January 13th, 2015, 06:55 AM
  2. Sloped glazing in sloped wall
    By stl4310 in forum Architecture and General Revit Questions
    Last Post: September 7th, 2012, 09:12 PM
  3. Just a Sloped Glazing system...
    By rkitect in forum Rendering and Gallery
    Last Post: December 6th, 2011, 08:58 PM
  4. Sloped Glazing.. upside down?
    By rkitect in forum Architecture and General Revit Questions
    Last Post: December 3rd, 2011, 04:44 PM
  5. sloped glazing mullion
    By jameshs in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 05:33 PM
