Thread: Counting Yes/Nos
    3,450
    03:46 AM
    Counting Yes/Nos
    Any good ideas (other than Dynamo ) on how to count up the number of Yes responses in a Schedule?
    I've tried adding another parameter with a formula (if LowVOC,1,0) and totaling that column.
    That kinda works, but it looks like !$%!$ on the Sheet.
    You can't hide the quantity column, because that hides the total, too.
    And graphically squishing the column down to almost no width also wipes out the total.
    In fact, now that I think about it, even with Dynamo, it would be the same problem.
    Member pivoarch's Avatar
    March 16, 2011
    Princeton, NJ
    380
    04:46 AM
    What if you just had a second schedule that does the totaling? You could sort by yes and no and then not itemize every instance then the count would be your total of yes no? It is kind of hacking and you'd have to stack multiple schedules on the sheet.
    2,882
    02:46 AM
    Make the text of the column white and remove the line to the left and youll get close. Still needs some width of course but the sub and total will still show black.
  1. Double Counting in Schedule
    By Brad Peters in forum Architecture and General Revit Questions
    Last Post: August 20th, 2016, 08:36 PM
  2. Furniture Schedule - Double Counting
    By john.warburton in forum Architecture and General Revit Questions
    Last Post: June 30th, 2014, 05:33 PM
  3. barrel counting question
    Last Post: March 2nd, 2012, 01:39 AM
  4. barrel counting question
    By lost again again in forum Architecture - Family Creation
    Last Post: February 29th, 2012, 03:04 PM
  5. Revit Kid: Brainstew ... 3 Years and Counting!
    Last Post: February 20th, 2012, 05:15 PM
