Hey guys, I have a small question for you all about Naviswork, I do have a lot of selection sets made from one project. I did export it , and import it back into another project. However, selection set do not find anything anymore. It is mostly because it is not linked to the append files. How are you working so all your search sets are set for all your projects? You keep the same name for all your append files?
thanks for your help!
Either search in all files because your data-structure and classification system is strong, Or start using dummy .nwc files (E, stairs, W, etc) that you already appended to your template, then when you get the real project files you rename those to the dummy names and override the old ones in your project folder.
My Navis "template" is a folder with 20+ files (1 nwf and a bunch of nwc's) and a handful of subfolders in it.
So if for example I have a dummy file named LGR - Structure , LGR - Architecture etc etc.. and week I rename their NWC the same name, update the NWF file, it should keep the search sets the way it is ?
that is what I tought , I wanted to make sure before a big project! thanks for your help Bjorn !
I will also back that up - all my Search Sets, I have to re-select the appended files in the project and Update them for that specific project so they work again.
I do have a couple of Selection Sets in my template, they're only for very minor and specific uses for hiding and unhiding roofs and slabs. It's my own method and it doesn't work well with Search Sets in the way I need it to so it's a very easy workaround. That's the only Selection Sets that gets used or needs to ever be used for me.
-TZ
