Thread: Hatch Patterns for Diffuser
    December 15, 2014
    60
    08:29 PM
    Attached a air terminal that I would like to use in my project. What I want to achieve is it should show honey comb hatch pattern on it's face. Was able to Put the hath pattern within the terminal but when we use it on the project it's not showing. Attached the revit family.
    Any leads would be greatly appreciated.
    1,841
    09:29 PM
    You need to edit that hatch in your project, not in the family. If a hatch is already in the project it will use that, no matter what you do to it in the family.
    December 15, 2014
    60
    08:29 PM
    Noticed it's in the model too but still didn't get it work, snapshot of Fill patterns in the model.
    1,841
    09:29 PM
    Opened your family and noticed that the materials of 2 of the 3 objects were not linked to a parameter (just the circular extrusion was). So change that too, so the material from your project actually works on the family.
    December 15, 2014
    60
    08:29 PM
    Hi Robin, did this and it override the visibility of the spigot in the floor plan. However updated the drafted the drafting pattern on to the face plate and it did worked.
    Sincere Thank you for your time and love this forum .
  1. create/ convert hatch patterns (.pat) to revit fill patterns
    Last Post: July 24th, 2015, 02:26 AM
  2. Revit hatch patterns -
    By basilmir in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 04:52 PM
  3. Wall Hatch Patterns
    Last Post: February 10th, 2012, 01:22 AM
  4. Some hatch patterns
    By JTB in forum Out There
    Last Post: July 10th, 2011, 12:21 PM
  5. Import hatch patterns from autocad. Export patterns from drafting to model.
    Last Post: June 15th, 2011, 10:56 PM
