Results 1 to 1 of 1
Thread: Flow Parameter unit change - heads up
    August 19, 2011
    New Hampshire
    531
    05:52 PM
    In case people were not aware, the imperial units for flow rate in piping changed. In years 2020 and below, flow rate parameter units were in gallons_us_per_minute. In 2021, flow rate parameter units were in us_gallons_per_minute. Content made before 2021 with flow parameters in their type catalogs will need to change to liters_per_minute in order to be version stable as gallons_us_per_hour and us_gallons_per_hour has the same issue.
    EDIT:: There are a lot more unit changes as well. Piping volume, structural forces...Was there a documented list of all the unit changes in 2021?
    EDIT 2:: I found this link for unit changes. I do not know if it is the full list, but it's a start. http://help.autodesk.com/view/RVT/20...ent_Units_html
  1. Revit wall architecture properties unit change
    By delprimo in forum Architecture and General Revit Questions
    Last Post: March 28th, 2020, 05:16 PM
  2. Replies: 3
    Last Post: July 28th, 2018, 02:46 AM
    Last Post: January 12th, 2018, 02:15 AM
  4. Replies: 0
    Last Post: December 15th, 2017, 06:45 AM
  5. Flow to a Fan coil unit
    By nick_h in forum MEP - General
    Last Post: March 23rd, 2015, 11:56 AM
