Hi all, can anybody help me with a sloping rebar set? I have a wall to a pit, the bottom is horizontal and the top needs to slope to follow the slab levels. i would like to use standard length bars and just increase the laps as required to suit the slope. it slopes about 200mm over 10m. So the bar in question that i would like to show as a sloping set on elevation will be a U-bar at the top of the wall. i don't see the point of messing about with the varying rebar set command for such a small slope. Any ideas appreciated.
Try Free Form Rebar method
https://drive.google.com/file/d/1Zit...ew?usp=sharing
Wow I can't insert or attach a mp4 or gif, this forum needs an update
Thanks Nurlan, but as you created it each bar would have different leg lengths. i wanted to keep leg lengths the same. Essentially every 200mm along the length of wall the U-bar will step down about 3mm to follow slope of wall top.
Then use the Varying Rebar Set, quite easy to do, nothing to mess with (Revit 2020, 2021). https://drive.google.com/file/d/1LtX...ew?usp=sharing
