Thread: Structural Wall Shear Keys
    February 8, 2021
    Virginia Beach, Va.
    4
    10:45 PM
    Does anyone know how to create the shapes needed to make a wall look like is has a notch at the bottom for a shear key and a groove along the top for a second row of wall to sit inside? I originally just used a generic wall and created a wall reveal that would remove the sections of wall I wanted, but in the 3D view, the channels and notches do not intersect. Does anyone know how to make these?
    Thank you.
    December 11, 2010
    Astana
    323
    08:45 AM
    Try Revit Parts
    Create parts from you walls, then divide the parts with a notch Division Profile.
    February 8, 2021
    Virginia Beach, Va.
    4
    10:45 PM
    Thank you for your help, that worked. Do you know if there is a way to make walls shaped like a "T" have the notches connect instead of having one of the notches stop at the edge of the other wall?
    December 11, 2010
    Astana
    323
    08:45 AM
    Place a face-based notch on the part where you want to connect the notches.
Name:	Connected notches.PNG
    February 8, 2021
    Virginia Beach, Va.
    4
    10:45 PM
    thank you very much for your help. I do greatly appreciate it.
    Justin
  1. Shear Wall Modeling/Schedules
    By EarthRevi in forum Structure - General Questions
    Last Post: January 17th, 2019, 06:51 AM
  2. Shear Wall Openings
    By thetragicjoy in forum Architecture and General Revit Questions
    Last Post: August 29th, 2016, 10:36 PM
  3. shear wall tags in plan
    Last Post: August 1st, 2013, 09:59 PM
  4. concrete shear wall elevations
    Last Post: April 16th, 2013, 09:21 PM
  5. Shear Wall Callout
    By TV98001 in forum Structure - Family Creation
    Last Post: May 25th, 2011, 05:51 PM
