Results 1 to 9 of 9
Thread: Wrong shadows in the perspective view with Revit 2021
    February 23, 2021
    5
    08:09 AM
    Help! All the shadows come out wrong in the perspective views. I donĺt know why. I'm desperate! In the plans the windows are ok, they aren't on different planes. I use a Surface 6 Pro 16 GB RAM with integrated graphic card.
ID:	40104Click image for larger version.
    4,539
    07:09 AM
    First off, welcome Francisca.
    (I've deleted your other thread where your attached pics weren't previewing)
    Yeah, something is definitely not right there! But afraid the only real option when Revit gets this confused is make the view anew (never fun with a perspective view you might have employed before)
    Before you do (delete this one) do any other views do it? have you tried cycling your view settings to "jog" it behaving properly?
    February 23, 2021
    5
    08:09 AM
    I have tried and tried, but the result doesn’t change
    4,539
    07:09 AM
    What have you tried?
    Specifics will help us diagnose. Screenshots (of settings) more the better.
    Mind, if you've always got to ask whether all this time (wasted) is worth it? Or does a new view (or others) corrupt equally? Because that might suggest other, higher, issues (graphics driver etc)
    For example, do shadows in axo views look okay?
    February 23, 2021
    5
    08:09 AM
    Yes, shadows in axo views are ok. Perspective views are altered. I have never succeeded in generating correct perspective shadows
    February 23, 2021
    5
    08:09 AM
    I’m sending you a screenshot
ID:	40107Click image for larger version.
    Attached Thumbnails Attached Thumbnails CDA3EE75-7656-4909-BC0B-522096CA2941.jpeg
  7.    #7
    4,539
    07:09 AM
    okay I think I've got it - the settings in first screenshot all look (my italian's rusty) - but the view preview in the samr image appears to show what looks like cad...?
    Weird as it sounds, hatch fills in 2D cad can cast shadows - and along with their general impact on performance (generally no-thanks to their over-large model space extents) the result effect can be, as you've observerd, quite horrible.
    One, remove (hide, turn off or better unload) from view/model... then
    two, go the extra and shrink your model space extent with a section box and/or reduce your draw distance.
    If it's not CAD (?) then even more a mystery.
  8.    #8
    February 23, 2021
    5
    08:09 AM
    I’ve removed 2Dcad and shrunk my model space extent with a section box, but the result is the same
  9.    #9
    December 11, 2010
    Astana
    303
    01:09 PM
    @Francisca, сan you copy one or two corner facade walls with windows into an empty project and post it here? Let's check if the same will happen on other computers.
  1. How long does it take to install Revit 2021 with the 2021.1.2 hotfix?
    By Markus in forum Architecture and General Revit Questions
    Last Post: January 7th, 2021, 01:01 AM
  2. Revit 2021.1.1 - Topo Viewrange cutoff in plan View
    By willsud in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2020, 11:40 AM
  3. Interior Perspective views not showing sun and shadows.
    By ndog in forum Architecture and General Revit Questions
    Last Post: August 11th, 2020, 10:45 PM
  4. [Revit 2021] What is the wrong with the material Browser?
    By Nsync in forum Architecture and General Revit Questions
    Last Post: April 14th, 2020, 06:44 PM
  5. Revit 2019 - Perspective 3D View / Depth of View Printing Issue
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: July 16th, 2018, 06:25 PM
