Hi All, i have seen this question asked on other forums but never seen an answer. But i could do with knowing the answer if there is one.
i would like to add mesh reinforcement to some foundations, but it appears mesh can only be added to walls and slabs? Surely that can't be right!
i can work round it by adding the correct bars at the correct spacing as we don't usually get asked to schedule mesh. But occasionally we do get asked for the amount of mesh required.
Any help appreciated.
https://www.revitforum.org/showthrea...strip-footings
You can create assemblies from rebars and then count as meshes.
