Thread: Revit - Paint Plan Accent Walls
    March 1, 2021
    05:27 AM
    Please reference the attached. This was done in Mircostation (yes, please don't shoot me). What would be the best way to do this "intelligently" in revit. In the past we just did detail lines on plan. I had a thought of using a filter that was based on material. Paint the wall with the accent material then use a filter to override the graphics in manner to suit.
    Member scourdx's Avatar
    July 4, 2013
    117
    10:27 PM
    Hope this is what you are looking for
    https://forums.autodesk.com/t5/revit.../td-p/10121514
    Convert to parts. Specify the material for that part and then use filter to highlight the material.
    March 1, 2021
    05:27 AM
    Thanks - that was my post I posted
    2,897
    10:27 PM
    Depending on the scale of the view this wont read as well as you might like. The thicken line will be centered on the Part rather than offset to one side as you have in your example. It will also thicken both sides of the Part which will again will be a problem at some point.
    You could also use Dynamo to place and manage a detail item in these locations. It could work off the Parts or even the painted wall if you want to get deep into the challenge!
  1. Replies: 1
    Last Post: January 31st, 2019, 02:59 AM
  2. how to show paint as surface on the plan view?
    By Duboli in forum Architecture and General Revit Questions
    Last Post: May 25th, 2017, 08:04 AM
  3. BIM Nightmare: Material takeoffs and Paint Schedules for Accent Walls
    By mendler in forum Architecture and General Revit Questions
    Last Post: July 22nd, 2015, 03:05 AM
  4. Accent Striping in Architectural Elevations
    Last Post: June 11th, 2015, 03:04 PM
  5. Slabs modeled after the walls are hiding the walls in plan
    By joshr in forum Architecture and General Revit Questions
    Last Post: November 25th, 2013, 10:20 PM
