Thread: Support beam location
    February 26, 2021
    United States
    5
    01:04 AM
    Hello,
    I see these type structures all the time at the beach, they are sun decks. I was never able to get close enough to see where they are supported underneath the platform & was wondering if anyone know where the load beams would be.
    Thanks in advance,
    Rodney
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    425
    06:04 PM
    Right under the Deck, with a transfer Columns into either Roof, or over the Building
    This would typically need to be all designed & sized by a structural engineer
    Last Post: August 31st, 2016, 03:15 PM
  2. Split sloping beam into 2 beams at column location
    By m77cck in forum Structure - General Questions
    Last Post: August 16th, 2012, 08:33 AM
  3. Beam System - Pick Support
    By alexo4141 in forum Structure - General Questions
    Last Post: May 30th, 2012, 05:53 PM
    Last Post: February 1st, 2012, 07:15 AM
  5. Revit OpEd: Location, Location and Location
    Last Post: August 26th, 2011, 03:00 PM
